Roof cover
Roof cover
Hi i saw some time ago on forum how to step by step remove and replace vinyl roof cover now i can not find it anyone help pls
- Guran
- Vehicle: ND - 1.5
Re: Roof cover
Hey Terry, I assume you're asking about removing the soft-top? Several guides are on the big forum:
http://www.miata.net/garage/garagetops.html
Let me know if you'd like an extra pair of hands. I've done a few of these now.
Re: Roof cover
Thanks Brian i will most likely go for the Joe Geyer window replacment listed in the sites you posted as there is really nothing wrong with the roof apart from the plastic window witch is cracked. As you know i patched it some time ago and it is holding fine with the adheisive i used so now to replace the entire window using the plywood was something i had thought about as the main prob is to keep flat will let you knw how i go it wont happen this week as car is booked for service and extractors to be fitted
Re: Roof cover
Well the cheap fix didnt work new top fitted last Sat all good now
