Waterpump install?
Technical Guides primarily to do with the NA series
13bgalant
Waterpump install?
Postby 13bgalant » Thu Mar 21, 2013 10:51 am
Hey guys did a coolent flush and change yesterday to find the water pump now leaking.
Is there a write up on how to do change the pump? I understand the timing belt and what not has to come off.
I hate doing timing stuff , so any help to point me in the right direction would be awesome.
ps I had 1 day of driving with rego before this happened lol
Re: Waterpump install?
Postby manga_blue » Thu Mar 21, 2013 11:37 am
What we call the Big Board, miata.net, has lots of write-ups.
The water pump one is here: http://www.miata.net/garage/water_pump.html
Also you can go through the technical guides sections of this forum: http://mx5cartalk.com/forum/viewforum.php?f=76. It's a good source for parts catalogues and workshop manuals, among other things.
13bgalant
Postby 13bgalant » Thu Mar 21, 2013 12:33 pm
Hey thanks a bunch!!! 8) 8)
Postby manga_blue » Thu Mar 21, 2013 12:58 pm
Sigh, just checked the miata.net write-up. I think it goes too far. If you're not replacing the timing belt then you don't have to remove the crankshaft belt and timing belt pulleys.
13bgalant
Postby 13bgalant » Fri Mar 22, 2013 9:20 am
so the water pump can be done without taking the timing belt off?
macaroni
Postby macaroni » Mon May 27, 2013 5:16 pm
Would also like to know if you can change the waterpump without taking off the timing belt.
gslender
Postby gslender » Mon May 27, 2013 10:01 pm
Nope. To remove the pump the belt must be interfered with. You could cable tie the belt to the top pulley, but to be honest, I'd be surprised if you can do it without eventually deciding to remove the belt to get the pump clear.
Return to β€œNA [1989 - 1997]”
