Parts required:
Toyota connector plugs
Part numbers for coil packs:
90080-19015
90919-02239
90080-19023
90919-02234
Part number for connector housing
90980-11885
Crimp pins
I got mine from here: http://www.bmotorsports.com/shop/produc ... ts_id/1567
16awg wire (different colours optional)
3 pin pigtail from the original coil pack
There are four pins on the Toyota coils that need to be connected to the engine bay wiring harness. Each one needs a wire for 12V, ground, trigger and tach signal. The two trigger signals and 12V are supplied from the original 3 pin coilpack plug, the coil packs are grounded directly to the cylinder head and the tach signal needs to be wired back to where the OEM ignitor was. Each Toyota coil pack has it's own ignitor circuit inside so the stock one can be binned. Two sets of wires need to be jumped on the original connector to get a trigger signal at the original coilpack plug. A 1k resistor is also required to be placed over the IG- and B+ pins in the diagnostics box to get the tacho to work.
To connect the wires together you can either solder them or use crimps. The red, white and blue wires are found on the 3 pin pigtail from the original coil pack while the yellow/blue and black/white wires are found on the ignitor plug pins 5 and 4. Coils 1 and 2 do not need tach signal wires unless running sequential spark.
Wires numbe 8 and 7, and 1 and 2 need to be connected together.
Picture of my completed loom without any wire insulation.
