Fire Extingisher Mount
- irwin83r
if its just a sheet of stainless like the one in the pic i can make them.
anyone have a drawing or able to pull one apart and give me some detailed photos and measurements?
price will depend on mat costs. i'll go to the stealstore and see if i can get trade rates through my firm, if welding is needed i have access to mig, tig and stick but am not a certified welder, and am not a gun welder... so i would rather dodge welding if we can.
- irwin83r
Haven't looked at the NC, but both the NA and NB need the bottle to sit a bit further forward of the seat frame mounting points. Then there is the matter of the slight rise in the floorpan at this point, and you need to get it as low as possible so that the seat can still slide over the bottle for any shorter drivers etc.
Never considered using plate, wouldn't be that cheap I imagine.
Motorsport is a disease, where the only cure is poverty!
The ego writes cheques that skill can't cash - DJ
- irwin83r
- Red Baron
For less than 30 bucks go down to Bunnings, buy a sheet of alloy plate, about 1.5mm checker alloy, you will also need a couple of longer bolts to replace the bolts from the seat. Cut to any shape you like as long as it fits under the seat runners and will take the extinguisher bracket and you have it.
The benefit with thin alloy is that you can force the shape to the floor and when bolted down it will take the shape of the runners.
My exthinguisher sits about 100mm forward so you get full movemnet of the seat and it really does not get in the way for passengers. No probs with scruitineers.
really no point being precious, who looks at the floor anyway.
baron
baron
Red
True Red NC Touring, Tein's, sways, beatrush chassis suite, roadstersports exhaust, starting to steer like a sports car, and stop like a bee with Hawk pads and DBA4000's! And still the wife's shopping cart, "Gold"
- Red Baron
With mine I needed another 5mm, not enough thread holding for my liking. If yours are ok then no problem
baron
baron
Red
- JBT
I just made a firex mounting for the passenger's side (driver's side is wider) from 3mm steel plate. Gawd it was hard to get hold of a small bit of plate without buying a truckload
Anyway, finally got a bit cut to my dimensions (roughly I might add) by a small welding shop. I drilled all the holes and painted it matt black. It is very unobtrusive and probably wouldn't even be noticed by 9 out of 10 people. If you don't have the gear to drill holes 12mm holes in steel, make a cardboard template and get the steel man to drill them and your firex mounting bracket holes as well.
This set up only allows about 100mm forward travel of the seat without unclipping the fire extinguisher, but my pax seat has been fully rearward since the car was bought 3 years ago, except to vacuum behind it
Here are some pics.......yes the front of the seat runners look like they need some paint and the car needs a bit of a vacuum - bloody flash
- green_comet
- Car Detailing Guru
I might be able to get some made up if people are interested.... I am already getting Radiator panels made.
http://www.aus-cartalk.com/viewtopic.php?t=16966
So these fire extinguisher mounts should be no worries at all...
- irwin83r
- TonyMax
JBT wrote:Anyway, finally got a bit cut to my dimensions (roughly I might add) by a small welding shop. I drilled all the holes and painted it matt black. It is very unobtrusive and probably wouldn't even be noticed by 9 out of 10 people. If you don't have the gear to drill holes 12mm holes in steel, make a cardboard template and get the steel man to drill them and your firex mounting bracket holes as well.
Here are some pics.......yes the front of the seat runners look like they need some paint and the car needs a bit of a vacuum - bloody flash![]()
Big ups to you for putting up these pics particularly the measurements, we now have one exactly the same in the passenger side of my wife's car ready for Phillip Island next weekend.
~the artist formerly known as MizMac~
Re: Fire Extingisher Mount
CAMS regs for the fastening from the fire extinguisher bracket to the mounting plate specify steel bolts. Here's part of AROCA's scrutineers check sheet for a Vic club day:
Rivets or self tappers won't get you through the scrutineers in the Vic events any more. Actually they shouldn't be allowed through anywhere. A loose fire extinguisher is a very lethal weapon.
AROCA wrote:Check Mounting Bracket
Mounting bracket is metal with at least one metal strap
Mounting bracket, strap and over centre clip is not damaged.
Mounting bracket is secured using minimum of 2 Grade-6 or greater bolts of a minimum 6mm diameter and self locking nuts.
A suitable sized body washer may be required to provide extra support for the bracket.
The securing system must be able to withstand a 25g deceleration.
- JBT
No, others were mentioning rivets. Just thought it worth broadcasting.JBT wrote:No rivets or self tappers used in the mounting system I described above.
- greenMachine
manga_blue wrote:No, others were mentioning rivets. Just thought it worth broadcasting.JBT wrote:No rivets or self tappers used in the mounting system I described above.
Wouldn't be the first, for sure. The rent-a-racer that I crewed on for the WP 300 used pop rivets
- Regie
- Vehicle: NC - V8
JBT, was the bracket made for your NC?
