COMPRESSION RATIO B6T PISTONS
spikey
Postby spikey » Wed Mar 15, 2006 4:10 pm
Just wondering if anyone know what compression ratio the factory B6t pistons run.any help would be appreciated.
Terry
Sheck
Postby Sheck » Wed Mar 15, 2006 7:53 pm
Dont quote me on this but i've always been under the impression that they were 7.8-7.9:1.
I remember reading about it somewhere a good while ago, so my memory is pretty foggy on it.
But i'd say it wouldnt be much higher than the above figure.
Try fordlaser.com forums, they will definately know.
Dave
spikey
compression
Postby spikey » Wed Mar 15, 2006 9:45 pm
Just checked on one of the Charts B6T run a 7.9-1 ratio,so it should be good for boosting.
Sean
Postby Sean » Fri Mar 17, 2006 7:58 pm
Yep 7.8 and 7.9, there was apparently a small variation and the later models are the lower comp ones. if you buy from mazda brand new you get 7.8:1
glen73
Re: COMPRESSION RATIO B6T PISTONS
Postby glen73 » Sat Mar 18, 2006 2:43 pm
spikey wrote:Just wondering if anyone know what compression ratio the factory B6t pistons run.any help would be appreciated.
Terry
seems to me your going FI. why didnt you keep the injectors you sold me for your project? theres nothing wrong with them is there :mrgreen:
spikey
b6t
Postby spikey » Mon Mar 20, 2006 11:19 pm
The only thing wrong with the injectors could be that they are too big for a 1.6 with 7.9:1 compression motor,so I have to source some 330cc for now.
spikey
b6t
Postby spikey » Mon Jul 03, 2006 7:14 pm
It works out my tuner is the problem and not the size of the injectors.
glen73
Re: b6t
Postby glen73 » Mon Jul 03, 2006 7:15 pm
spikey wrote:It works out my tuner is the problem and not the size of the injectors.
lollollol
find yourself someone decent.
