Whats the Maximum I can shave the head???
neil d
Postby neil d » Tue Apr 25, 2006 8:10 pm
Hi All
I'm currently running an 1800 engine in my MX5 2f race car and for some stupid reason I assumed the guy who completed the head work would have shaved the head in order to increase the compression however he did not.
I know the standard head is 133.8-134 mm what I don't know is what is the minimum height before valve hit piston? I'm currently running the Wisco high compression pistons and a mild-ish cam at 265deg duration and peak cam lift of .34892 inch.
Assuming that I have the pistons flush with the top of the block and running a standard head gasket does anybody know what is the maximum I can take of the head?
If nobody know does any body know where I could get such information?
Any help would be greatly appreciated.
Neil
SP Race Car
RS Clio
ML 300
maxwolfie
Postby maxwolfie » Tue Apr 25, 2006 8:18 pm
20 thou is a safe limit but I'm pretty sure many have gone more with no problems.
i dont know much about head shaving, that is all i recall
Check the big forum (www.miata.net forum) for more info- There's tonnes on this
'89 JDM NA6 (black)
2" s/s ex., 4-2-1 extractors, high flow cat, RX-7 AFM + pod, lightened fly, h/d clutch, 2 way lsd, slotted rtrs, Racing beat type II front bar, Speedy 17" wheels
maxwolfie
Postby maxwolfie » Tue Apr 25, 2006 10:07 pm
He's an idea's man!
'89 JDM NA6 (black)
OMY005
Postby OMY005 » Tue Apr 25, 2006 11:09 pm
Daz 27 wrote:rip the head off, put some soft putty on the valves, fit the head back on, turn the engine over a couple of times by hand, rip the head off again & measure how thick the putty is.
Best and most accurate way to do it, even if someone has the exact same combo then dialing in the cam timing can change the clearance. Better to take some extra time now to avoid the possibility of a sump full of piston pieces and valve heads. :)
Previously, White 95 NA 1.8 Hard Top,Stock standard
Now, 2016 Fiat 500x, 2014 Fiat 500, 2015 ND GT 2.0
