Heat wrapping
Astroboysoup
Heat wrapping
Postby Astroboysoup » Wed May 10, 2006 1:53 pm
so what do you guys use to hold down the heat wrap on exhaust manifolds and piping?
I've seen some people use stainless steel hose camps? Anything else I can use that is Cheap?
AustCars.net - It's like Facebook but for cars!
SuperMazdaKart
Postby SuperMazdaKart » Wed May 10, 2006 2:37 pm
stainless steel hoseclamps are rather cheap & effective though. don't think you can do any better for less..
Astroboysoup
Postby Astroboysoup » Wed May 10, 2006 3:21 pm
suppose i'll go out and buy some hose clamps.. then i can put my new/old extractors on..
SuperMazdaKart
Postby SuperMazdaKart » Wed May 10, 2006 3:35 pm
it's a very tedious job that heatwrap stuff.
put it on before they get fitted i say
Astroboysoup
Postby Astroboysoup » Wed May 10, 2006 4:08 pm
yeh already did it once on my original extractors when they were on the car.. hurt my knees from over extending them to reach the manifold.
got your shocks installed yet?
and has anyone made that pipe that goes from the cone air pop filter to the cowl?
SuperMazdaKart
Postby SuperMazdaKart » Wed May 10, 2006 4:19 pm
nup, waiting pending my job contract getting renewed or not. just found out my front right side shocker is different from the other 3. some blue US made shocker, probably had a leak at a dealership sometime in the past. might explain why my right turns feel a bit different from the lefts.
you got that yellow mushroom filter don't you? wouldn't be a hard diy project. some pvc rain piping & maybe like a plastic bowl in the right size & shape.
Astroboysoup
Postby Astroboysoup » Wed May 10, 2006 4:37 pm
yeh i just got a cone filter with heat shielding around it...
whats my obsession with heat soak.. pfff.. i dunno
but yeh just need to make the snorkle bit from the end of that to the cowl.. should be too hard..
SuperMazdaKart
Postby SuperMazdaKart » Wed May 10, 2006 4:47 pm
loch stewart version 2 copy i gather
Astroboysoup
Postby Astroboysoup » Wed May 10, 2006 4:48 pm
yep... or mx5mania copy....
which ever came first
Philip Lee
Postby Philip Lee » Wed May 10, 2006 5:28 pm
Astroboysoup wrote:yeh i just got a cone filter with heat shielding around it...
where did u get this from?? i want one too!!
Astroboysoup
Postby Astroboysoup » Wed May 10, 2006 5:55 pm
Philip Lee
Postby Philip Lee » Wed May 10, 2006 6:09 pm
u sure don't want the chrome ones for bling? :P
pls let us know if they're any good.
cheers
Astroboysoup
Postby Astroboysoup » Wed May 10, 2006 7:32 pm
heheh yeh im sure
you can bid on this C one here http://cgi.ebay.com.au/JUSTJAP-DOME-TYP ... dZViewItem
im not bidding on that one... he has many and puts them back online every week. I've been watching them for months now.
I'm thinking that its not really CF and just plastic painted to look like CF.
btw
that heat wrap stuff is really itchy.
dv8one
Postby dv8one » Wed May 10, 2006 7:51 pm
just use 'tie wire' to hold the wrap on. worked fine on my old drag car.
jolt
Postby jolt » Wed May 10, 2006 8:27 pm
Wouldn't the chrome one reflect some of the heat away from the intake too? Whereas I'd imagine the darkness of the carbon fibre look ones would only increase heatsoak wouldn't it?
Rod
>apexi >arc >hondata >maxim works >a-rf >trust >magnecor >ngk >greddy >endless >yokohama >brown davis >sabelt >defi >zoom >fpv >alpine >corns >autoexe >levoc >royal purple >rs aizawa >beatrush >carbing >cusco >aragosta >garage vary
