upgrade - CAI and/or filter
Looking at manias website I see several different options and i am insterested in knowing the effectiveness of each. I am looking for some increase in power or response together with a deeper note to my engine, at a minimal cost.
so what are your thoughts?
1. CAI - Mania Cold Air Intake
Utilises the high pressure area at the base of the windscreen to reduce intake temperature and vacuum, increasing power and torque. Gives a deep, rich induction note.
2.Unifilter Custom Induction Rampod
Completely replaces the factory air box and paper filter with a high flow, foam-type air filter. Experience power gains of up to 4% and torque gain of up to 6% plus improved throttle response. Kit includes the Rampod and all the mounting hardware. No Cutting or Drilling Needed. Bolts To Existing Mounts.
3.Simota Heat Sheild Filter
Simta heat sheild filter. Comes complete with stainless steel heat sheild. Cotton re washable filter.
4. an /or
Mania Enlarged Intake System
The largest available MX-5 intake. Improves power and torque. Comes complete with water redirection piping, connection hardware, silicone adaptors, clamps and hoses. Can be combined with Mania Cold Air Intake.
thanks in advance.
Ben
4. an /or
thanks in advance.
Ben
Re: upgrade - CAI and/or filter
Ben wrote: I am looking for some increase in power or response together with a deeper note to my engine, at a minimal cost.
Start with the Mania CAI, I have just fitted the Loch Stewart CAI ( much like Manias one ) and the best bang for buck there is. You will get what you are looking for if you can stand the sound of the firewall being cut.
Richard
Mazda Tribute - its a boat
Coming - Jayco Eagle wind up camper - woo hoo
Ex cars 2007 NC LE Radiant Ebony, 1990 Eunos Neo Green LE
- maxwolfie
Steve 818 wrote:Or as a slightly cheaper alternative you could get a Simota pod filter with the plastic cowling, go to your local hardware store and buy a 100mm to 75mm PVC adapter, a short (30 cm) length of 75mm PVC dunny pipe and any color paint that takes your fancy. Then go home, assemble it yourself, get the 75mm hole drilled in your firewall and fit it yourself after painting it your favourite color.
Now that's a bang-for-your-bucks mod!!!
DIY and save yourself a fortune!!!!!!!
Oh and those 'enlarged intake systems' are total BS unless you get them properly insulated or they are made out of something that doesn't have 'heat transfer' as one of it's more pronounced properties.....
Sounds like an idea
Fugg spending 600+ just to get cold air down the intake, seriously...
'89 JDM NA6 (black)
2" s/s ex., 4-2-1 extractors, high flow cat, RX-7 AFM + pod, lightened fly, h/d clutch, 2 way lsd, slotted rtrs, Racing beat type II front bar, Speedy 17" wheels
- Matty
sounds familiar Steve...
http://autospeed.drive.com.au/cms/A_0892/article.html
- irwin83r
- sab
Ben wrote:i have a 90 Le NA6A
The DIY VERSION LOOKS GREAT AND LOOKS LIKJE FUN BUT I DONT KNOW IF I AM UP TO IT REALLY.
HRRMMM Maybe ill just have to pay mania
I have the Mania one in my car. You'll be really happy with its intake noise and performance gains over a stock setup.
I previously had made up the dunny pipe intake and it worked ok except for a few rattles and vibration noises.
If you don't mind spending the money, and want something that looks great, then go for the Mainia CAI.
- randymx5
Does anyone know the 'name' or 'brand' of the CAI that looks like a snorkle (well scoop) that sits above the bonnet line and bellow the wiper blades and funnels air possibly into a Loch Stewart or silmilar intake..
wow did that make sense!! Ive confused myself!! Dont make me draw a picture!!...I have seen pictures posted on this forum but cannt seem to find them..
R&ALL
RED 1990 MX5, AVO stage II, 148.5rwKw
- sab
Steve 818 wrote:sab wrote:If you don't mind spending the money, and want something that looks great, then go for the Mainia CAI.
That reminds me of the Sportsmart ads on tv where the young guy laughs his head off at the old guy who always buys the more expensive sporting equipment because he thinks that it will be 'better'.
Any CAI will offer improved performance over the factory intake. Whether someone chooses to spend $60 or $600 on their intake, they will be getting pretty much the same function.
The difference in price only refers to a preference in aesthetics.
Funny ad that Sportsmart one. The old guy is probably loaded anyway, so he probably couldn't give a sh!t.
I wouldn't go as far as saying that "Any CAI will offer improved performance" but would say most will. Have seen some pretty dodgy home made setups in the past.
Ben, I suppose it all comes down to what you can afford, are prepared to spend and what your tastes are. Some people want to let their cars look good, others prefer function despite the look. Some prefer the looks and the function. It all about what you want.
In my opinion, the $250 Mania one is worth its money if you want to spend it. I'm sure others with the Mania intake would agree.
- Andrew
- sab
- irwin83r
