style bars, roll bars and schedule J compliance...
rain902
Postby rain902 » Thu Jun 15, 2006 10:59 pm
Bevan wrote:That sux! Surely the width of the cars body, with the height of the roll bar, and being strapped in tight by a harness would more than protect your shoulder? :? :evil:
watch some crash test dummy video sometime - your head flops around more than you would believe!
ive seen comas caused by side / rear helmet impacts to the uprights of a bar - and that was with harness and race seat.
2013 Australian hillclimb champion 2F
2013 qld hillclimb champion 2F
Qld & Aus 2F state record holder-mt cotton
2014 vic hillclimb champion - 2A
Cal
Postby Cal » Fri Jun 16, 2006 10:47 am
bigdog wrote:I haven't heard anything to this effect on my CAMS grapevine Cal. Do you have a reliable source on this? It would seem to be a tall order in most road based vehicles (V8 Supercars would come to mind - the bars in these are all around the driver - and most sports sedans I've seen would have trouble with this too).
The source is better than reliable. I've been hearing about it for 12 months, but thought it was just speculation. It's not.
Cal.
CT
Postby CT » Fri Jun 16, 2006 1:31 pm
For the record, V8 Supercar roll cages do not comply with CAMS. That's right. They do not comply with CAMS. They are built to the V8SC companies specs. If you purchased a V8 supercar and wanted to run it in a CAMS category, you would need to change the cage. The \"Larry\" bar is a prime example of where the V8s differ from CAMs specs. 8)
bigdog
King of the kennel
Postby bigdog » Fri Jun 16, 2006 1:38 pm
Bloody typical :roll: :roll: :roll:
JBT
Postby JBT » Fri Jun 16, 2006 2:34 pm
CT wrote:For the record, V8 Supercar roll cages do not comply with CAMS.
If that's correct, it shows what a farce the roll bar/cage rules are becoming.
Red Baron
Postby Red Baron » Fri Jun 16, 2006 8:29 pm
This whole CAMS thing just makes no sense at all.
I have decided in my best interest to take up Knitting and have purchased at great expense the entire series of Yes Minister, including I might add, the editors cuts.
After several weeks of Knitting, and I have done some very fast stuff as well as the more sensible speed for special curves, trying to keep my eye on the telly at the same time, I have got to say I now understand it all.
CAMS seems to be populated by a bunch of Knitters that watch too much Yes Minister on telly.
Fuc@* your brain. I have now started counting Blue Smarties to try and get some sanity back.
baron
Red
True Red NC Touring, Tein's, sways, beatrush chassis suite, roadstersports exhaust, starting to steer like a sports car, and stop like a bee with Hawk pads and DBA4000's! And still the wife's shopping cart, "Gold"
Red Baron
Postby Red Baron » Sun Jun 25, 2006 9:09 pm
mmmm hide the blue pill and give him the red pill
Excellent, you have my point well in hand!!!!
CAMS are in a position to ream a group of enthusiasts, by simple bungling. \"Yes Minister\" is a very apt example of how this happens in these environments.
Knitting, unless I choose to change my vehicle, then I might just as well take it up, cause in an MX5 I \"WILL BE REGULATED OUT\"
High time that the MX-5 Clubs of Australia got together on this, put up a unified front, and give the CAMS \"MINISTERS\" a wake up call.
Don't you all think??????
I would really like to be competing again this year, but I can assure you that I am not prepared to put up my hard earned for entry fees, tyres etc just to be told that I do not comply.
Not pointing the finger at the Scrutineers, because they can only interpret the book, and the \"BOOK\", might just as well be turned into a series called \"YES MINISTER\"
baron
Red
irwin83r
Postby irwin83r » Mon Jun 26, 2006 7:18 pm
CAMS is starting to sound like a government body..
one of the main reasons i bought my 5 was because of how suited they are to low level track work and now i'm hearing it wont be possible to have a road reg's 5 on the track.
2\" from the shoulder would put most jap cars out the window in fact alot of cars in general would need some MAJOR interior work or stripping to get a decent sized bar to sit next to your shoulder with a 2\" gap...
and now im hearing if i have it all signed off before a set date i wont have to worry about spending hundreds or even buying a different car all together? jesus its personalised plates all over again...
:roll:
mossy
Postby mossy » Mon Jun 26, 2006 8:32 pm
I'm a little slow on the uptake here but does this mean a club day with the WRX club or AROCA will affect us racing unless we have a proper roll cage built?
Return to “MX5 Motor Sport”
