No Auto bashing please !
Robbo107672
Postby Robbo107672 » Thu Jun 22, 2006 9:22 pm
My 1990 NA6 (import) has a 'loose' shifter. I have seen this on a number of early Autos.
Has anyone been able to get a kit of bush's or is there another way to fix it so that it is tight again? Any idea on costs also appreciated.
I still works fine, but when I pull it back it's just not easy to get to the right spot.
Robbo
[strike]Laguna Blue NA6, NB Titanium SE, 1993 Red NA6, 1990 BRG NA6[/strike], Granpa Grey NC1
MX5 #5, an NC series 1 this time !
AJ
Postby AJ » Thu Jun 22, 2006 9:27 pm
sounds like the spring that holds pressure on the little doohickey that pokes in the slots for the gear selection is a bit weak from old age 8)
XMX5 Rogues
kitkat
Postby kitkat » Thu Jun 22, 2006 9:49 pm
AJ wrote:sounds like the spring that holds pressure on the little doohickey that pokes in the slots for the gear selection is a bit weak from old age 8)
Impotent?
AJ
Postby AJ » Thu Jun 22, 2006 9:50 pm
needs some Viagra kitkat :lol:
XMX5 Rogues
kitkat
Postby kitkat » Thu Jun 22, 2006 10:16 pm
yes im sure viagra would stiffen that spring right up... :lol:
maxwolfie
Postby maxwolfie » Thu Jun 22, 2006 10:30 pm
youll need a manual box to fix that
sorry
'89 JDM NA6 (black)
2" s/s ex., 4-2-1 extractors, high flow cat, RX-7 AFM + pod, lightened fly, h/d clutch, 2 way lsd, slotted rtrs, Racing beat type II front bar, Speedy 17" wheels
AJ
Postby AJ » Thu Jun 22, 2006 10:39 pm
come on guys, they man asked a reasonable question 8)
XMX5 Rogues
jules
Guitar Hero
Postby jules » Fri Jun 23, 2006 10:37 am
Perhaps ask on the BIG forum www.miata.net
There probably aren't a lot of auto owners here.
Jules
Andrew
Postby Andrew » Fri Jun 23, 2006 10:52 am
Robbo107672
Postby Robbo107672 » Thu Jun 29, 2006 8:48 pm
Thanks for the Links Andrew !
I have ordered some bushes from the UK, I'm sure that is my problem.
Robbo
Andrew
Postby Andrew » Thu Jun 29, 2006 10:14 pm
No problem :P
ampz
Vehicle: NA6 - Turbo
Postby ampz » Fri Jun 30, 2006 4:51 pm
bushes from the uk?
you can pick them up here cheaply enough... around $1.50 each for an astina... shame shifter on the mx5 i think
Huh?
