Remedy: drive with the top down except in inclement weather.
Bevan wrote:My best guess is there's someting attached to the car somewhere that's causing vibrations when the car is moving or making noise when wind passes over/through it. Or it could very well be the wheel bearings, as you suggested. I think this is quite a cheap exercise.
gregord wrote:At highway speeds the noise is so great I have resorted to earplugs.
So I changed the tyres - no difference.
It is there almost until the car stops - so I don't think it is tyres.
I have a 99', automatic with Michelin 195/50 R 15(82V)(SX-GT) Pilot SX tires.
Is anyone who has these tires experiencing a tremendous amount of noise
from them. These seem to have an exceptionally loud hum that is actually
painful between 60 and 70 mph.
My husband can't hear it, but I attribute that to hearing loss from loud
classical music.
Laurie
Try inflating your tires to 30 psi up from factory recommended 26 psi. The
tire noise should be dramaticaly less, but the ride may be a little harsher. I
noticed the same thing except the other way around. After servicing the car at
a dealer for the first time, on the way home I noticed tire noise which was
not there before. Turns out the dealer deflated my tires down to the factory
spec of 26psi, the ride however was much smoother.
Serge.
99 Red Sport.
Bevan wrote:Worth a try?
gregord wrote:Who makes Precedas?
