turbo clutch problems and adjustment
4sfed5
Vehicle: NA6 - Turbo
Postby 4sfed5 » Sat Jul 08, 2006 9:26 am
Ive got a 1800 flywheel and an \"xtreme\" 700kg clutch and full face disc in my 1600 turbo and its started slipping, if i re bleed and adjust its ok for a few days then it slips again. ive got a NEW slave in it and the master is only a year old. it is driving me nuts.
has anyone had similar clutch slipping problems? its almost like the pressure in the line builds up not allowing the clutch to be released somehow...im wondering if the near new master has gone bad???
it used to engage low to the floor and now its high after only about 2000k's on the new clutch and several adjustments.
ANY IDEAS??? (how much for a sprung 6 puck disc??)
Sean
Postby Sean » Sat Jul 08, 2006 1:16 pm
I don't have the answer :cry: but I have a similar extreme clutch and can confirm it is living up to my spastic monkey driving style...
sabretooth
Postby sabretooth » Sat Jul 08, 2006 1:56 pm
I'd pull the master and have a look at the piston and the seals. It sounds a little like air is getting in?
SileNceR
Postby SileNceR » Sat Jul 08, 2006 9:02 pm
check that no oil is leaking onto the clutch also - althought the problem shouldn't go away when adjusting the clutch settings if this were the case
HAD (sold 2010) 2000 Emerald Green Mica NB8B
NOW 2001 Brilliant Black NB8B
OTHER 2010 Mazda 3 BL MPS Luxury
4sfed5
Postby 4sfed5 » Fri Jul 14, 2006 4:42 pm
well i just pulled the master cylinder and its stuffed.....great, less than a year old and its leaking fluid out the piston seal and has rusted the circlip,(and probably the inside of my firewall too) damn. ive got a replacement so will put it in and readjust and bleed again.Im getting very very good at this now!!!!! :( this cars clutch hydraulics are a joke, had nothing but problems with this car.
bigdog
King of the kennel
Postby bigdog » Fri Jul 14, 2006 5:03 pm
Sean wrote:I don't have the answer :cry: but I have a similar extreme clutch and can confirm it is living up to my spastic monkey driving style...
Pic of Sean at max boost... :P :mrgreen:
Sean
Postby Sean » Sat Jul 15, 2006 3:31 pm
Hahahaha 8)
glen73
Postby glen73 » Sun Jul 16, 2006 8:14 pm
4sfed5 wrote:well i just pulled the master cylinder and its stuffed.....great, less than a year old and its leaking fluid out the piston seal and has rusted the circlip,(and probably the inside of my firewall too) damn. ive got a replacement so will put it in and readjust and bleed again.Im getting very very good at this now!!!!! :( this cars clutch hydraulics are a joke, had nothing but problems with this car.
the only thing that i can think of that would eat seals and your car is brake fluid. one time when my fluid was low in my troopy i used brake fluid to get me home which was fine as i flushed it out the next day. if i hadnt it would eat up all the important bits over time.
4sfed5
Postby 4sfed5 » Mon Jul 17, 2006 9:57 am
Glen..not sure what you mean there....the clutch system uses brake fluid.
basically what happened was that the piston seal on the master cly failed and rusted the end of the cylinder at the circlip end.(pedal end)..... problem is that the piston should return hard up against the circlip when in normal driving operation. with the rusty clylinder end and circlip, the piston would not return all the way causing the clutch to slip.
jules
Guitar Hero
Postby jules » Mon Jul 17, 2006 2:24 pm
"Mr Compression lockup to you sonny!!"
Jules
glen73
Postby glen73 » Mon Jul 17, 2006 4:49 pm
yer mate, cough cough i was cough just joking cough. :mrgreen:
Woo
Vehicle: 10AE - Turbo
Postby Woo » Mon Jul 17, 2006 9:30 pm
How can this be ????
If your slave (or MC) is stuffed doesn't your clutch just NOT disengage?
If your clutch is slipping then the MC cylinder is not your problem.
Two things will cause a clutch to slip
1) Lack of friction surface
2) Incorrect free play (on the pedal or thrust bearing)
I'd be looking at the later
Wòó
btw, I hadn't realised that Sean was so cute hehehe, great pic
Very slightly modified 10AE #2562 ..... one of 149 in Australia :wink:
Race what you brung ..... And hope you brung enough
4sfed5
Postby 4sfed5 » Tue Jul 18, 2006 9:08 am
Woo.
it was the master cylinder leaking fluid very very very slowly causing the circlip to rust. this meant that when you take your foot off the clutch it wouldnt return to the freeplay position and kept pressure in the clutch line like you still had your foot on the clutch. it stopped about 3-4mm short of the circlip and this translates to a HUGE amount of travel at the pedal.
how do you attatch photos to posts??Ill take a pic to show what i mean.
glen73
Postby glen73 » Tue Jul 18, 2006 10:07 pm
http://imageshack.us/index.php
go there, upload from computer, then copy and paste your link into a reply :)
