Castrol SRF Brake Fluid
Boags
Postby Boags » Fri Aug 04, 2006 2:59 pm
Hi all,
I have been told by my local brake man that this is amazing stuff, and well worth the extra cost. He has a race motorbike and cannot boil it. He is still using the same fluid he put in a year ago so it really takes the pounding you can give it.
I also remember *i think* Sean saying it was a good mod.
So, firstly, does anyone know somewhere it can be bought comparitively cheap - I was told $160 for 1L :shock: But I am not expecting it much cheaper than that, maybe between $120 - $140?
Secondly, seeing as i'd only need about 500ml, anyone want to go 50/50 on a bottle :mrgreen:
Boags 8)
CT
Postby CT » Fri Aug 04, 2006 3:20 pm
Have you tried Motul RBF600 or the Ferodo \"Racing\" Fluid? A new option is Elf that Revo Racegear have supposedly starting selling. It's the same stuff the WRC cars use. I went from SRF to Elf and it's much better again. FWIW, a lot of the supercar teams use RBF600. 8)
Boags
Postby Boags » Tue Aug 08, 2006 10:13 am
OK,
I was told that a lot of the \"Racing fluids\" require a complete cleanout of your brake lines. If there is any residue of the old fluid it (i have no idea how) fooks the new fluid. I was told SRF doesn't do this, hence it is great for a road car. Any clarification would be appreciated.
This guy at the brake shop also said he tried several brands of \"Racing fluid\" and they all boil sooner or later.
Boags
Matty
Postby Matty » Tue Aug 08, 2006 11:48 am
One of the purported benefits of the SRF is the long service intervals (18 months).
I've used it without problems in the past. Gone cheaper now that I haven't been tracking lately...
green_comet
Car Detailing Guru
Postby green_comet » Tue Aug 08, 2006 3:10 pm
Im using EBC BF307+ racing brakefluid in my car, it runs great..
http://www.ebcbrakes.co.nz/brakefluid/
I have about 4 500ml bottles left if you are interested in some. Costs $55 per 500ml... 2 bottles are needed to clean out your system.. I could do 2 bottles for $60 plus postage (approx $10) if you are interested.. just let me know.. :D
cheers
Ryan
Boags
Postby Boags » Tue Aug 08, 2006 10:03 pm
Do i need to do a complete flush out if i use this stuff, or will it go straight in after the old fluid is out?
Tempting, very tempting.
Boags
green_comet
Car Detailing Guru
Postby green_comet » Wed Aug 09, 2006 10:20 pm
Boags'MX5 wrote:Do i need to do a complete flush out if i use this stuff, or will it go straight in after the old fluid is out?
Boags
I did a complete flush when i put it in my car, since it is a dot 4 brake fluid you should be able to just fill up without doing a complete flush. I wouldnt recommend it though, as your mixing a high performance fluid with a standard... Besides you should flush the fluid from your brakes every couple years or so, as the brake fluid soaks up moisture overtime and effects the fluids braking capabilities. Took about an hour all up to do a complete flush, and used about a bottle and a half. :D
cheers
Ryan
rhysk
Vehicle: NB8A - Supercharged
Postby rhysk » Wed Aug 09, 2006 11:47 pm
I run SRF.
$120 but that is through my mechanic.
Syringe as much of the old stuff out of the M/C as you can. Then run a clear tube off the brake line and pump until you see the new stuff.
supercharged NB (in Brisbane) - qr 1:01:75 (s), 1:05.90 (c)
jaguar xjr supercharged v8
