CAMS CLASS 2F SPECS
fish
CAMS CLASS 2F SPECS
Postby fish » Wed Aug 16, 2006 1:14 pm
Can anyone give me the Car specs / regulations for the 2F Cams class or
advise on where I can obtain them.
thanks
born again 1994 NA8 2F RACE CAR ....No 42
Li7hium
Postby Li7hium » Wed Aug 16, 2006 1:52 pm
The generic response around here usually is to buy the CAMS manual.
But I'm after these details as well if someone has them and is willing to provide their knowledge.
Matt
NA8
Wakefield 1:14:78 28-6-09! Oran Park GP 1:27:73 30-03-08 Oran Park South 54:50 14-10-2007 Eastern Creek 2:02:44 6-8-07
BRZ
Pheasant Wood 1:05.4940
fish
Postby fish » Wed Aug 16, 2006 2:05 pm
hhmmm great will look forward to that then
I only want the basic regs not every little detail like:
what can be done to:
tyres
engine
brakes
gearbox & diff
Boyracer
MX-5 Encyclopedia
Postby Boyracer » Thu Aug 17, 2006 10:07 am
You really need to get the CAMS manual...
Here are a few basics for 2F.
-Tyres are radial road tyres,can use R spec.
-Diff must use ratio available to particular model...can use Torsen.
-Engine must be from that model.
-Inlet manifold has to be standard from that model.
-Engine internals are pretty much free but must be aprox. same capacity.
-Gearbox same as standard car.
-Must have working headlights and windows.
-Have to run passenger seat but all other trim can be removed.
Hope this helps...let me know if you need to know more.
Cal
Postby Cal » Thu Aug 17, 2006 11:58 am
Come to the next Top Gear meeting at QR and have a look over the cars. Most are 2F.
Cal.
fish
Postby fish » Thu Aug 17, 2006 12:11 pm
thanks guys ...will definately be out at the next top gear meeting may be driving in it if all goes to plan ...
Cal
Postby Cal » Thu Aug 17, 2006 1:16 pm
Why not rent one of Brian and Henri's race car rentals and have a run: http://www.racecarrentals.com.au/
Cal.
neil d
Postby neil d » Fri Aug 18, 2006 9:53 am
Boyracer wrote:You really need to get the CAMS manual...
Suspension is relatively free in that you can run coil overs however you must retain standard arms.
Brakes are free.
With respect to the donk you can pull metal out of the head however you can not weld extra metal in. Cams/pistons are free and you can run whatever computer you want. Headers and remaining exhaust is free.
Obviously you need a Cams approved Roll cage, kill switch and extinguisher.
That should cover the 2f regs
I echo what cal said come out to the top gear meet and speak to the guys or alternatively you can come around to my house and have a look over my car.
Neil
SP Race Car
RS Clio
ML 300
SKYHI
Postby SKYHI » Tue May 27, 2008 3:59 pm
Most will probably know, but for those that don't you can get all the regs online now:
http://www.camsmanual.com.au/racing.asp
Paul.
Pilsner
Postby Pilsner » Wed May 28, 2008 6:06 pm
To be eligibile for 2F car needs to comply with Cams Class I rule:
Vehicles in Class I shall be representative of mass-produced vehicles, featuring fully enclosed bodywork, of which a minimum of 500 were produced world wide in at least one twelve calendar month period. Unless otherwise specified, such vehicles shall compete in their basic form for the model represented.
So you can run NA, NB, NBSE, NC but you can't run a NBSP (only a 103 produced).
To run the SE you need to fit a 34mm restrictor in the turbo inlet housing as per Cams drawing and run standard turbo and intercooler
Now with a new toy
Fisher Fury + SP race Car + Supercharged NB + Canstel Clubman + Stock NA
Cal
Postby Cal » Wed Jun 04, 2008 10:26 am
Pilsner wrote:To run the SE you need to fit a 34mm restrictor in the turbo inlet housing as per Cams drawing and run standard turbo and intercooler
Done properly, one of these should easily produce more more than the current top 2F cars at 210 - 220hp or whatever.
Return to “MX5 Motor Sport”
