Turbo Oil Return in to sump
rjr666
Postby rjr666 » Thu Aug 31, 2006 10:19 pm
Ok dont toast me yet, im sure this topic has been covered, but i want to put the oil return in a diffrent position,
.... in between the Engine mount and the back of the Air con compressor as you can see in this picture...
The idea is to mount it as high as possible above the oil level hopefully.
Thanks guys
I need a sponsor
Russellb
RIP Nov 2014
Postby Russellb » Thu Aug 31, 2006 10:44 pm
Yep that about where I put mine :)
My ClubmanRebuild
MX5 SE Rally car is HERE :)
rjr666
Postby rjr666 » Thu Aug 31, 2006 11:25 pm
mmm nice speedflow fittings ;)
Yeah bout the same height, just futher back towards to dip stiick where the two ridges jut out inbween there i belive...
My idea is to use a 90degree drill, a turned down drill and drill the side :D without having to take a/c compressor off ect...
I need a sponsor
Russellb
RIP Nov 2014
Postby Russellb » Thu Aug 31, 2006 11:32 pm
That Photo Is with the A/C Bracket Off and teh A/C pump hanging on a piece of Wire :) Didn't even remove the Lines
Thank for the Comment on the Speedflow fittings :) I used them on all the water and oil lines Adds plenty of Bling factor
My ClubmanRebuild
Moggy
Postby Moggy » Fri Sep 01, 2006 6:45 am
I put mine almost exactly where you marked it rjr666. Haven't had any issues...
Users browsing this forum: Google [Bot] and 5 guests
