I did it... and it works!
Astroboysoup
Postby Astroboysoup » Sat Sep 02, 2006 4:58 pm
I just completed my first timing belt, alternator belt and power steering belt change!!!
yay for me.. and the car still works...
bonus i say!!!
AustCars.net - It's like Facebook but for cars!
irwin83r
Postby irwin83r » Sat Sep 02, 2006 5:32 pm
CONGRATS!
just hope you remember the alternator clutch plate fasterner :shock:
Astroboysoup
Postby Astroboysoup » Sat Sep 02, 2006 5:36 pm
the what?
JBT
Postby JBT » Sat Sep 02, 2006 6:27 pm
Well done.......and don't take any notice of irwin83r :)
Astroboysoup
Postby Astroboysoup » Mon Sep 04, 2006 9:06 am
just a little question about the intake cam alignment.
I was arguing with my dad about the alignment of the intake came. At the from of the gear I was saying that it should lign up with the E mark on the gear and the engine head.
Dad was saying that there is a mark at the back near the CAS that needed to line up. I was dong some reading and couldn't find any mention of this mark anywhere in any texts.
Anyway, we lined it up to the mark on the cams and the CAS instead of the E on the cam gears. So i think the intake cam gear is about 4 degrees forward of the E mark on the engine head.
The engine sounds and feels like it has its timing advanced but not quite. cos its still set on 10 at the moment.
Anyone knows what happens when you don't have the intake cam lined up to particular marks? In arguing with dad and then giving in to him, have i just produced more power for my car?
adamjp
Postby adamjp » Mon Sep 04, 2006 9:12 am
1 tooth on the sotck cam drive gears is allegedly worth 12degrees.
I once put mine back together 1 tooth out - and it was VERY obvious. The car idled like sh*t, ran like sh*t and had no power. It could not even make it up the driveway to the road.
The indicators on the front of the engine are the ones to use.
Intake cam E = E on the head.
Exhaust cam I = I on the head. Don't know why they chose those indicators but there you go.
I have always found one little trick is to mark the cam gears with a permanent marker so the mark is at the VERY top of the gear when they are in TDC position.
Adam
JBT
Postby JBT » Mon Sep 04, 2006 9:44 am
If you have put the belt on, didn't touch the CAS and your ignition timing hasn't changed (on an NA6), then the intake cam is aligned correctly.
One tooth is about 7 degrees (there are about 50 teeth on the cam wheel).
See this thread too.
CT
Postby CT » Mon Sep 04, 2006 10:05 am
The other trick is to make sure your inlet cams number 1 lobes point to the inlet manifold (parallel to the ground) and your exhaust cams number 1 lobes are pointing to the exhaust manifold (parallel to the ground) when the engine is at #1 TDC. And, there should be 19 teeth on the belt between the gears. Rotate the engine two full revolutions and they should all still be the same. Never fails. 8)
irwin83r
Postby irwin83r » Wed Sep 06, 2006 9:38 pm
Astroboysoup wrote:the what?
haha :lol:
nah just teasin
well done
SuperMazdaKart
Postby SuperMazdaKart » Wed Sep 06, 2006 9:50 pm
i gather no crank key problems
Astroboysoup
Postby Astroboysoup » Thu Sep 07, 2006 9:40 am
nope
i didn't have to take the main crank bolt off which would have been a bitch... but i didn't see any leaks or anything from the area after i gave it a good old clean. so the main crank seal didn't need to be replaced.
so.. over all pretty easy.
too me two weekends cos im constantly going out and drinking but it should have taken me that long
Astroboysoup
Postby Astroboysoup » Thu Sep 07, 2006 10:01 am
nope
