rest will be custom
irwin83r wrote:
can the inside of the turbo be refabed to fit a larger empelor or a more effcient one?
Not if you want it to be eligible to race in prod sports. Turbo mods are not allowed.
Okibi wrote:I was at Wheelspin this afternoon and they had a plug in ECU loom to use the new Wolf ECU on an SE, or could make one to suit a motec.
I'll try and post a photo of it soon.
THE REAL BORIS wrote:The stock bov has a reputation for leak; I cannot comment beyond that. However, the spring is weak enough to allow even a minor vacuum to keep the valve open. Shutting this valve earlier, with a stronger spring action (the GFB swap is adjustable) enables the turbo to boost earlier by closing the bypass at a higher manifold vacuum. You will notice that the car has more low down torque as a result.
And, if it is leaking, top end will improve too?
150rwkw has been shown by all the FM work to be the limit on stock injectors (as I am sure you well know). But the bov is hiding there as the only thing you have not changed yet. Bet it's shaking in it's boots. I recently fitted a new steel inlet elbow to the throttle body and the bov line was too restrictive, causing flutter on changes. I m/c it out and now it's great. So, with all your mods. you may need an upgraded bov anyway?
ASE05 wrote:...Okibi, do ya know if it was a custom loom or one Wolf have been workin' on? Either way I'm SOOPER DOOPER keen!
What other mods was this SE sporting?
irwin83r wrote:soo... no one has really had a stabb at it yet?
Maximum rear wheel kilowatts for a SE turbo??
just at a stab with the standard turbine, manifolds. everything else over cooked would achieve.....? 200rwkw???
AJ wrote:pretty long reach getting MORE than a kw a CC at the rear wheels
