80kw atw on Mania Dyno!
Spranga
Postby Spranga » Sat Sep 30, 2006 11:33 pm
Mania have their dyno running and my NA8 apparently has 80kws! The dyno has replicated several power figures from other dynos which are reputed to be accurate so I am confident this figure is also accurate. Given the only modification to my car is a Mania CAI I think 80kws is very good. I think standard is about 70-72 kws so either my engine is a freak or the Mania CAI is a very worthwhile mod.
Dan
PS
Thanks again for your efforts today David, Daniel, Andre and Simone.... you guys are tops!
nath
Postby nath » Sun Oct 01, 2006 1:58 am
That wasn't your car getting the brown davis put in today was it Dan?
Should have introduced myself... my bad.
80rwkw is tasty. Anything else done to it or is it purely just the mania intake?
N.
Mr_Q
Postby Mr_Q » Sun Oct 01, 2006 10:04 am
And more importantly ... how are the new springs? :)
Mister Q
Had: Red 2004 SE, Red 1993 NA8 Clubman, Green 1991 NA6 LE
Spranga
Postby Spranga » Sun Oct 01, 2006 2:30 pm
Springs are great thanks Mr Q, they must work better after the second installation... :roll: I am happy with the compromise as they seem to match the shocks quite well with a controlled but not crashy ride. The cornering is sharper however I think they may get a little choppy with mid corner bumps.
Yeah that was me getting the BD installed Nath. I was also trying to get my second hand konis installed however we had a few dramas as they were actually to suit a NB and made the car look like a Landcruiser (there was almost 10cm between the guard and rear tyre!). Are you the guy who is doing the turbo, the guy who bought the radiator, or the guy who was having the heater hoses done :D
My car has no engine mods besides the CAI. The timing is standard and the plugs and leads are at least 3 years old!
Dan
irwin83r
Postby irwin83r » Sun Oct 01, 2006 4:12 pm
Spranga wrote:Springs are great thanks Mr Q, they must work better after the second installation... :roll: I am happy with the compromise as they seem to match the shocks quite well with a controlled but not crashy ride. The cornering is sharper however I think they may get a little choppy with mid corner bumps.
Dan
so the car sits alot lower with the standard shocks hey? is good to hear. lower than standard now or just about the same?
Spranga
Postby Spranga » Sun Oct 01, 2006 11:32 pm
Dan
Lower than standard about the same as most NA koni/king combinations. How your beast running? No more burping I hope.
irwin83r
Postby irwin83r » Mon Oct 02, 2006 6:48 pm
Spranga wrote:Lower than standard about the same as most NA koni/king combinations. How your beast running? No more burping I hope.
thats good. looked a tad wierd on the other shocks :P
yeah car hasnt missed a beat since but im starting to get the HP itch again :?
rodent
강남 스타일
Postby rodent » Mon Oct 02, 2006 10:37 pm
Spranga/Mr_Q - how much to go for a spin on Mania's new dyno? I'd love to see how my little beastie rates :D
Postby Okibi » Mon Oct 02, 2006 11:30 pm
Spranga wrote:...My car has no engine mods besides the CAI. The timing is standard and the plugs and leads are at least 3 years old! ...
Exhaust is stock too?
Spranga
Postby Spranga » Tue Oct 03, 2006 9:32 am
Exhaust is stock :shock:
You would have to ask Mr Q what it cost to have a run on the dyno. David wanted to put mine on the dyno just to see what numbers it would come up with, so there was no charge. The dyno is a new toy for David and Daniel so give them a call and I am sure they will look after you!
Fuzzlet
Postby Fuzzlet » Tue Oct 03, 2006 9:12 pm
Spranga wrote:Exhaust is stock :shock:
To give you an idea of cost, its gonna cost me about $1835 to use their dyno.....but thats also including new ECU.....and waaaaah pssst :P
rodent
강남 스타일
Postby rodent » Wed Oct 04, 2006 2:56 am
Wait - your tarrrbo install's costing you under $2k?? :shock:
Sean
Postby Sean » Wed Oct 04, 2006 8:47 pm
I was thinking - Damn that's cheap!
bigdog
King of the kennel
Postby bigdog » Wed Oct 04, 2006 9:35 pm
Nah - he's getting an ecu and a cd that makes a \"waaaaah pssst\" noise :mrgreen: :P :mrgreen:
nfs13b
Vehicle: 10AE - Turbo
Postby nfs13b » Fri Oct 06, 2006 4:57 pm
I'd be interested to put my car on the dyno if the cost wasnt too much.....
Whens the next dyno day...
MX5 13B - NFS Racing
PRO-MX5 PB 7.46 @ 179mph & 1.07 60ft
