OIl cooler on, oil pressure low
The knocking sound has completely dissappered so it may of been something else.
I'll prolly go to a thinner oil very soon that should hopefully get the pressure up a little.
As for the thermostat its not nessesary as the oil heats up pretty quick already (time it take for the cold start high oil pressure to stop is only a few hundred meters more than previous). The RX7 cooler looks a similar inlet/outlet size to mine but is much longer and about 3/4 - 1/2 the height of mine (but i'll pop down to my rotary mechanic to see if he has any laying around to compare it too).
I'm thinking i should try and get some fatter lines and fittings. I'm thinking something like 18-20mm internal dia - or maybe an oil cooler with bigger inlet/outlets.
Sigh what a muck around! heheh
Just thinking, i remember seeing a hex screw (for the relif valve i belive) on the outside of the oil pump - does turning this do anything? Perhaps i could boost up the pressure a little using this?
Cheers for your help guys!!!
Dave
Dave
- sabretooth
- CT
Sheck wrote:Bigger lines/fittings will work cause any restriction before the pressure sensor will register as a pressure loss. (the filter is before the sensor)
Yea i'm curious as to whether any one else has had this problem..
Dave
I use -8 lines for mine and it hasn't even been a big problem. Lines are a little over 1 meter each. What size are yours currently?
- CT
- Inf3ct0R
I got the car goin again finnaly and with the new 5-40 oil it runs at a higher pressure when cold (hurraah!!) but when warm i can see it build up nicely as i take off from the lights or something then the relive vale must open cause the gauge flicks back down to around 2bar (from the spike of between 2.5-3bar).
I'll prolly be picking up an RX7 ser4 oil cooler on monday (100 bux woot) but then the only problem i'll have is where to fit such a monsterous oil cooler!! they are soo long!!!! I'm thinking behind the radiator, as thats about the only spot it'll go and thats where they are on an RX7 anyways.
(i'll be extra cut if it doesnt fix things!!!)
Dave
Dave
- Inf3ct0R
Sheck wrote:I got the car goin again finnaly and with the new 5-40 oil it runs at a higher pressure when cold (hurraah!!) but when warm i can see it build up nicely as i take off from the lights or something then the relive vale must open cause the gauge flicks back down to around 2bar (from the spike of between 2.5-3bar).
Dave
really, is that where they are mounted on the rx7's...
I was thinking of mounting it there away from the stones. the heat from the radiator will still be cooler than the oil anyway. but now I have decided to make a shroud for it behind the radiator
- orx626
- Vehicle: NC - Rotary
Sheck wrote:I'm thinking behind the radiator, as thats about the only spot it'll go and thats where they are on an RX7 anyways.
FYI...on first (excluding 3rd series as it has an oil to water cooler) and second generation RX-7's they are actually mounted below the radiator and therefore receive ambient air, not second-hand warmer air that has gone through the radiator. The standard aussie third gen RX-7 has one mounted off to the left hand side behind the front bar like an RX-8.
Oh really? i never looked at my bro's old rx7 when it was jacked up so it looked like it sat behind the rad, very low but still looked like it was there.
Well i done some more thinking and looking and it may be able to fit behind the bumper just on top of the bumper support (plastic thingy), then i'll cut a hole in the front bar to let air through - this will then got throught the top of the radiator.
I wont figure it out till i get it and see if it physically fits in there. Their the only places i can think of it going as they're so big.
Perhaps if i put it behind the rad then i will make up some custom shrouding and undertray to let fresh air pass over it...
Cheers for that danny!
Dave
Dave
- Boags
Sheck wrote:Well i done some more thinking and looking and it may be able to fit behind the bumper just on top of the bumper support (plastic thingy), then i'll cut a hole in the front bar to let air through - this will then got throught the top of the radiator.
Don't you have an intercooler there?
- Sean
I've considered routing the return line from the turbo through an oil cooler before returning the freshly cooled oil to the sump.
I've been too concerned about teh oil draining down easily back to the sump to actually go ahead with teh plan, but have a similar idea in mind...
When the car comes back from the panel shop and goes in to get some more engine development we're going to try my new idea... If it shows promise I'll let you all know
. Tad expensive, but should work nicely.
