The thing with the 6 speed is, IIRC, 1st and 6th in the six speed are pretty much the same as 1st and 5th in the 5 speed, we just have a closer ratio spread for those tricky \"2nd's too low and 3rd's too high\" corners.
Dropping to first on the move
Casey wrote:Dropping to first on the move- shouldn't even be necessary in an SE
MX5-SP wrote:Casey wrote:Dropping to first on the move- shouldn't even be necessary in an SE
I can understand that down Canberra way, but we do have some seriously twisty hair-pins up this way ...and when you're stuck behind one of those slow Malibu's going up the mountain, one occasionally has to resort to novel tactics to stay awake.
Casey wrote:[ You must come and try them yourself to gain a better understanding of the region.
For mine though, the roads in Tassie and New Zealand are hard to beat. Come to think of it, even climbing over Arthur's Pass on the South Island in a Toyota Echo didn't require a downchange into first.
StanTheMan wrote:
ROFLMHO......if its the malibu i think youre talking about i doubt you could keep up with it in the twitiest of hairpin mountain rdseven with a factory sponsored turbo
...It is. And it seems it's been a vain attempt to flush him out from his hiding spot. He hasn't been seen around here for MONTHS. Some are speculating he's had to trade Tweety Bird in for "something more sensible!!!"....
