Slipping clutch - need help/advice
- JSE
my clutch is slipping majorly. It only does it after about 45mins of driving or on very hot days (like lately in Sydney). What is the problem, can it be fixed, do i need a new clutch and what should I do?
If I need a new clutch i will be putting in a beefy heavy duty one (if that answers any future questions/posts).
thanks in advance
thanks in advance
- zoomzoom
- Vehicle: NA6 - Turbo
Have you checked your oil lately? Perhaps when the car warms up and the oil thins it can get through the rear main oil seal faster and get onto your clutch. Anyhow leaky rear main or not its only a matter of time before you need a new clutch all together so I would start saving/planning now. And while your there you might as well do the rear main too.
- JBT
Re: Slipping clutch - need help/advice
JSE wrote: What is the problem, can it be fixed, do i need a new clutch and what should I do?
a. stuffed clutch;
b. yes:
c. yes; and
d. get a new clutch kit , pilot bearing and rear engine seal and have them fitted.
- JBT
JSE wrote:thanks...so has nothing to do with the master & slave cylinders?
Not if you mean clutch slip as in the clutch allows you to engage gears but engine RPM changes without any immediate change in speed - a bit like an automatic car struggling to accelerate in Drive. Generally noticed when going up an incline in a slightly higher gear than you would like to be in.
- JSE
- AJ
nah, that's the poor old clutch trying to grab hold with what little it has left........you've got the maximum life out of it by the sounds............of course oil leaking from the rear main would cause the same effect, same prognosis tho...........new clutch assembly
XMX5 Rogues
- john!
AJ wrote:nah, that's the poor old clutch trying to grab hold with what little it has left........you've got the maximum life out of it by the sounds............of course oil leaking from the rear main would cause the same effect, same prognosis tho...........new clutch assembly
Hmmm, can't seem to recall my clutch doing that when it was nearly dead.
It might be worth having a check of your engine mounts as well, especially on an older car. The shaking they make sounds like what you have described. They are going to look like this if they are gone, big crack in the rubber bits.
john
- Andy Wana
Is a new clutch assembly costly to install?
I ♥ asymmetry
- CT
- jules
- Guitar Hero
- MasterZ
my clutch was slipping once. but it was my fault. i had a freebie in class and we went to bass point (big gravel spot) and we were having fun doing donuts and crap. but by the end of the day, it was back to normal
1992 Mazda MX5 Turbo | 2004 VW Golf GTI | 2010.5 VW R36 Passat Wagon | 1985 Mazda HBES 929 13b Turbo | 1987 Mazda RX7 FC3S Turbo | KE20 Corolla Coupe
- jules
- Guitar Hero
