Headlights won't go down?
- zoomzoom
- Vehicle: NA6 - Turbo
I was fooling around with the plugs under the steering column and all of a sudden the lights went up and won't come down. Has anyone else had this happen before? Any suggestions?
Thanks, Tim
Thanks, Tim
- JSE
- zoomzoom
- Vehicle: ND - 2
zoomzoom wrote:yea did all that. Does anyone know where the headlight relay is located? Or if there is anything else electrical in the line such as a fuse that would cause them to go up but not down?
such as the open lights button above the hazard lights? could be related
- godfather of saké
devolutio wrote:zoomzoom wrote:yea did all that. Does anyone know where the headlight relay is located? Or if there is anything else electrical in the line such as a fuse that would cause them to go up but not down?
That would be my guess too. I have a sneaking suspicion that there is a separate circuit for up, and one for down. When I was mucking around installing my sleepy-eye controller (which wires into the retractor button) I stuffed something up and could only get the lights to go up but not down. I think the "down" circuit goes thru the retractor button.
- zoomzoom
I hadn't touched that plug at all, but I did try unplugging it, plugging it, wiggling it etc. I think the headlights down is a closed circuit and when you press the button or unplug it, the circuit is broked(open) thus taking the voltage away from a changeover relay which switches to the headlights up mode. This is only my assumption and is the only way I can explain the unplugging of the switch making them go up. But I still cannot find why they are up now, I figure the circuit must be broken somewhere along the line but where? And I also did try bridging the plug that goes into the lights go up lights go down button.
Oh someone must have been through similar... please help, I dont want my 5 to be permanently bugeyed
- STV
- Vehicle: ND - 2
This sounds stupid (and makes no sense to me either) but try this...
Have the headlights always up button depressed when you plug its connector in as opposed to open when you plug the connector in.
I seem to recall that mine did this while i was dicking around with the stereo install for about a week!
Best of luck though..
STV
STV
Where is 'Home Sweet Home'?
- Sean
- zoomzoom
- JBT
Check the retractor relay connection/function. I believe it is under the dash as shown in this picture.
It is not in the engine bay as in the USA market cars.
Check here for wiring diagrams. Good luck, a few people have had such problems. Post results and photos if you can when you finally sort it.
