Experience with Wolf V500
Robbo107672
Postby Robbo107672 » Fri Dec 22, 2006 9:00 am
Hi,
Has anyone had any experience with the latest generation of Wolf EMS V500 ?
I am looking into this as it can now plug straight into a stock wiring harness and has on-board vacum.
thanks, rob
glen73
Postby glen73 » Fri Dec 22, 2006 12:56 pm
i have heard that an autronic puts out a more power standard than what a wolf does all tuned up
this was only here say from a bloke that builds expensive race motors.
16bit
Vehicle: NB8A - Supercharged
Postby 16bit » Fri Dec 22, 2006 1:07 pm
how much to autronics cost and where can i get one?
glen73
Postby glen73 » Fri Dec 22, 2006 1:10 pm
google
Boags
Postby Boags » Fri Dec 22, 2006 1:24 pm
A LOT more than a plug and play wolf. Maybe twice the price?
glen73
Postby glen73 » Fri Dec 22, 2006 1:29 pm
i know, im not saying or recommending or bagging ecu's here, look at me i run a microtech...... i was just surprised there was such a difference in ecu's. i think it comes down to whether you have to ask how much or not?
ZenArcher
Postby ZenArcher » Fri Dec 22, 2006 2:56 pm
I would have thought it would have more to do with the tuner.
If the tuner knows more about the intricate things/options with the computer he/she is tuning on whichever motor/vehicle it is, then they will get the best tune possible.
Whereas if they really don't know much at all about the computer/motor combination they are tuning and it's associated software, then they won't have the skills to do as good a job.
adfox
Postby adfox » Fri Dec 22, 2006 4:05 pm
One reason for difference in the results you get from different ECUs is the tuning resolution. In the cheaper units with less tuning points you have to comprimise, often ending up above or below a sweet spot.
Russellb
RIP Nov 2014
Postby Russellb » Fri Dec 22, 2006 4:10 pm
An Autronic SM4 will cost you $2350 with inbuilt map sensor wiring
harness and Air temp sensor. Then you need to wire it in. If you can follow
a wiring Diagram it is pretty straight forward .
What Model MX5 do you have ???
My ClubmanRebuild
MX5 SE Rally car is HERE :)
Russellb
RIP Nov 2014
Postby Russellb » Fri Dec 22, 2006 4:13 pm
glen73 wrote:i have heard that an autronic puts out a more power standard than what a wolf does all tuned up
All after market ECU will make around the same Power.
The big differance is that the More Expensive ones are easyer to drive
as an every day car.
My ClubmanRebuild
Robbo107672
Postby Robbo107672 » Sat Dec 23, 2006 10:07 am
Hi,
Thanks for comments, I am interested in the most recent Wolf... It has apparently been significantly updated from previous units so I'm wondering if some of the opinion's here are based on old models..
I have not done any research into ECU's b4 so I have to do some reading.
I have a '90 NA6 and really want to get rid of the AFM and all the plumbing to clean up the engine bay. I would like to just put a pod filter on the drivers side behind the head light. I may then have to do some exhaust work to get full benefit before I get a really good tune done. I guess I then have options for a turbo in the future but don't know if that will ever happen. (who knows?, these MX5's are very addictive cars... :evil: )
zoomzoom
Vehicle: NA6 - Turbo
Postby zoomzoom » Sat Dec 23, 2006 6:02 pm
Have a look at the Hydra Nemesis, I don't know much about them but I see FM uses them in they're top kits and to get most power. There is a place in Aus who sells them for I think around $1500. I was curious about them and want to see what other ppl think of them. They must be ok if FM uses them?
Fatty
Postby Fatty » Sun Dec 24, 2006 3:03 pm
check out the adaptronic (australian made) and the megasquirt too.
Postby Okibi » Thu Dec 28, 2006 7:39 am
Rob, www.wheelspin.com.au have put the Wolf V500 on an NB(SE) MX-5s and perhaps some NA MX-5s too.
They've also done quite a few V400s, the new electronic dash is quite nice.
Sean
Postby Sean » Mon Jan 01, 2007 4:10 pm
Find a tuner you're happy with and ask him what ECU he wants you to use for the spefic application.
No point speing big $$$ on an ECU to find the guy you want is a novice with that model or brand.
I've seen cars with basic piggybacks run exceptionally well and another car with a high spec Haltech run poorly - The haltch had a basic tune. The owner took it to a haltech specialist and the car was transformed - perfect idle, more power and BETTER economy!
