Not to sound like a kill joy guys, but have any of you checked to see if having an exposed pod is street legal? I've been told that an un-encapsulated pod is a defect in NSW. Perhaps someone can clarify.
The BEGi system is sought of encapsulated.
saboteur wrote:I have heard something along those lines, but the heat shield separates it enough from the engine bay surely?
Noise from filters and valves
Avoid fitting your vehicle with a pod-type air filter. This filter increases engine induction noise and may also increase exhaust gas pollution. Under clause 20 of the Regulation, it is an offence to modify an engine's air intake when it results in an engine noise level exceeding the maximum level specified in the Regulation.
Modifying or repairing an engine so the exhaust system noise level exceeds the prescribed level or altering an air intake system or exhaust system so the noise level exceeds the noise limit (clause 20)
Do not fit blow-off valves that vent directly into the atmosphere. Blow-off valves that vent back into the induction system are allowed.
Waste gate valves are nonstandard pressure release valves for turbochargers. These devices increase the noise from engines and can cause disturbance. If you are fitting these valves, ensure they do not vent directly into the atmosphere but into the exhaust system upstream of any mufflers.
defective noise control equipment includes:
(a) equipment that allows the emission of more noise than the original noise control equipment fitted by the vehicle manufacturer, or
(b) equipment that has, in the opinion of an authorised officer, been modified in a way that makes it less effective than it would have been if not for the modification, or
(c) equipment that allows gas to escape from a place other than the intended exhaust outlet, or
(d) if the equipment concerned comprises a system of mufflers—the system contains fewer mufflers than the original system fitted by the vehicle manufacturer.
The Muffin Man wrote:Be prepared, once you hit boost youll sound like an F-15. Its really noisey (good noise)
C+C wrote:can we make sure with whom ever we go with, that the kits are complete, including shield and all the bits. Some people o/s have complained of missing parts in packages.
saboteur wrote:C+C wrote:can we make sure with whom ever we go with, that the kits are complete, including shield and all the bits. Some people o/s have complained of missing parts in packages.
I just had a chat to Aricjm15 on ICQ and he said that he is fine to check the contents of the packages before shipping them over to us, so that's a big bonus.
C+C wrote:So we have 4 confirmed for the AEM (myself, PT, Saboteur and Blackster), can you please contact the suppliers to confirm on this. So i guess this will make delivery cheaper if split 4 ways ;)
