Any ideas? Is the gearbox about to..... DIE?
saboteur wrote:So it's better to let the synchros spin up the input shaft?
zoomzoom wrote:the throttle blip will only match the engine speed to the output but still leaves the synchros and clutch to spin up the main and input shafts. I still dont see how double clutching is going to prematurely wear components, if anything it should be making them last longer
