Leaking coolant problem, need part number
Astroboysoup
Postby Astroboysoup » Mon Jan 15, 2007 10:58 am
ok guys heres a challenge for ya.. i need a party number for something ive never noticed on my car before.
Its at the rear of the engine head. its a rubber end cap that ripped a little.
it sits on a pipe at the rear of the head.
ive taken many pictures to try and identify the little bugger.
end cap part number# ???
http://www.flickr.com/photos/48821477@N00/357545048/
http://www.flickr.com/photos/48821477@N00/357545050/
http://www.flickr.com/photos/48821477@N00/357545055/
http://www.flickr.com/photos/48821477@N00/357545060/
http://www.flickr.com/photos/48821477@N00/357545062/
lowmiata
Postby lowmiata » Mon Jan 15, 2007 2:20 pm
does it have a thread at all on the pipe? or is it pipe clamped?
if you are desperate find a bit of hose roughly the same size block one end, us a bolt don the tube and clamp it then clamp it onto the block
I cant say i've ever noticed the fitting and cant make it out from the pics clearly enough to jog the memory
but if it has a thread then chances are you can get something from a hose/fitting shop to block it
if it has no thread I can only assume it is pipe clamped on?
In which case the bolt in the pipe might get you out of trouble for wa while
good luck!
EVI15 1998 to 2008
JBT
Postby JBT » Mon Jan 15, 2007 2:42 pm
Part # FEA7-13-104
Wuey
Postby Wuey » Mon Jan 15, 2007 3:18 pm
Yup, it's that little bugger.
Part no. FEA713104 about $4.00 from a Mazda dealer.
See list at the bottom of this page.
Image 2004 SE
Astroboysoup
Postby Astroboysoup » Mon Jan 15, 2007 3:18 pm
this forum rocks...
thanks guys
esp jbt
thats the little bugger that i have to pull off and replace.
part ordered and hopefully replaced tomorrow.
... got scared that i blew the head and had a crack in it.
Postby bruce » Mon Jan 15, 2007 4:35 pm
'Nahh, just had an ice cream'.
That is the funniest thing I've read on this forum :mrgreen:
ampz
Vehicle: NA6 - Turbo
Postby ampz » Mon Jan 15, 2007 8:05 pm
Out of curiosity...
Could one use that thread, to water cool a turbo?
Huh?
