How do I know if I have an LSD?
- Fuzzlet
With the rain sydney got last night I decided to test to see if I had an LSD....Nice controlled drift....so the answer is yes, it hasn't tried to run away yet
- Bevan
Fuzzlet wrote:With the rain sydney got last night I decided to test to see if I had an LSD....Nice controlled drift....so the answer is yes, it hasn't tried to run away yet
I suppose I have an LSD too! I'd want to, paid enough to buy it and have it installed.
- Boags
If there isn't much traction (in the wet) you can drift easily without an LSD. The test is to sit somewhere in the dry, lock the steering wheel to one side, the do a semi-aggressive take-off (not clutch-dump). If the ass just flicks then you have LSD, if the inside spins; open...
Boags
- Boags
zoomzoom wrote:Kitty, an open diff will only spin one wheel when one has traction and one doesn't, if you see the workings of an open diff you will see why
What happens if neither of them have traction?
Boags'MX5 wrote:zoomzoom wrote:Kitty, an open diff will only spin one wheel when one has traction and one doesn't, if you see the workings of an open diff you will see why
Wind down the boost
- kitkat
Ill assume thats in reply to my post...
I said:
An OPEN diff WILL lock up BOTH wheels if the clutched is dumped.
- Bevan
Will work without roll back too. A high revving clutch dump will definitely leave two black marks on take-off. I did that in my last MX5 which didn't have an LSD.GP wrote:Yes Kitkat this will work if you do whats called a rollback first, Classic hoons method with an open diff
- kitkat
Bevan wrote:Will work without roll back too. A high revving clutch dump will definitely leave two black marks on take-off. I did that in my last MX5 which didn't have an LSD.GP wrote:Yes Kitkat this will work if you do whats called a rollback first, Classic hoons method with an open diff
Sure does...
The good ol open diff E30 love to lock up the rears... could even pop the clutch while heading around corners and it would lock up both and send it into a drift (wet tho)... Dont ask me how i know that tho
- Boags
kitkat wrote:zoomzoom wrote:Kitty, an open diff will only spin one wheel when one has traction and one doesn't, if you see the workings of an open diff you will see why
Hence my question:
I wrote:What happens if neither of them have traction?
