Time for a service on my NB8B = Dodgy Day?
Bevan
Postby Bevan » Wed Jan 24, 2007 11:55 am
Last night on the way to soccer training, she got introduced into the next generation revving out in second gear. 8) So within the next month or so, i'd love to give her a present and do a 100,000km service and a complete detail.
I plan on doing this in the driveway or lawn or at someone's house for a dodgy day... DID SOMEONE SAY DOGY DAY?!?!?! :lol:
I'll hit MX5Parts and see what sort of price i'm looking at in buying all this stuff.
Looking in this thread and this Miata.net page for the 2001 model service, I have the following list:
    Air filter clean
    Fuel filter
    CHECK Plugs and leads (not that old)
    Brake and clutch hydraulic systems flush
    Coolant flush
    Timing belt
    Water pump + gaskets
    Cam and crank seals
    Valve cover gasket
    alternator belt
    a/c - p/s belt
    Gear box oil
    Engine oil and filter
    Gearstick top and lower hats
    Exhaust gaskets (the never ending leaking SPM exhaust)
    Install short shifter
I think that's about it. :? :)
Some things that i'm a little confused about are these suggestions:
    Idler pulley
    tensioner pulley
    tensioner spring
    OCV Orings
    OCV oil pipe washers
Can anyone shed any light on this list and make anymore suggestions on what else there is? Thanks all. :)
Astroboysoup
Postby Astroboysoup » Wed Jan 24, 2007 4:27 pm
doing a similar thing this weekend at my place already
other MX5ers in adelaide are more than welcome to come along
If somehow I/we manage to get up on Saturday morning I'll be rewiring the speakers in my car. They keep cutting out from moisture and stuff.
If anyone plans to buy a head unit between now and then feel free to come over and install.
Or if you want to rewire your speakers and install new ones also feel free to come over. More hands can work faster to lay more cable quicker. I hope.
Sunday will be a car servicing day. If you feel like changin your spark plugs and oil, oil filter, air filter, and do a coolant flush come over then. Would help if you buy all the parts first. :) I'll be doing all the above and a cam belt readjustment for my dyno tune.
So who's coming, I'll supply alcohol and Wii and soap.
please PM me if you're coming
*thread stolen*
AustCars.net - It's like Facebook but for cars!
jules
Guitar Hero
Re: Time for a service on my NB8B = Dodgy Day?
Postby jules » Wed Jan 24, 2007 4:46 pm
    Idler pulley
    tensioner pulley
    tensioner spring
    OCV Orings
Hey Bevan,
As a word of advice, get ALL this stuff from MXparts UK. It's much cheaper and the bits will arrive in no time.
As far as the other bits you have mentioned
    Idler pulley - is one of two pulleys that maintain tension on timing belt
    tensioner pulley - is same as above, but a tensioned item (adjustable)
    tensioner spring - is attached to above to create tension on the belt.
    OCV Orings - not sure what this is.
    OCV oil pipe washers - I assume this is the rubber "O" ring that goes on the water pump outlet pipe.
Bevan
Postby Bevan » Wed Jan 24, 2007 5:07 pm
Astroboysoup wrote:*snip*
Maybe move it to a new thread? :)
STV
Postby STV » Wed Jan 24, 2007 5:15 pm
happy to lend a hand before uni goes back...
i am not that clued up, but am happy to be spanner passer and learn alot..
cheers
STV
Where is 'Home Sweet Home'?
marcusus
Postby marcusus » Wed Jan 24, 2007 9:13 pm
Ooer... dodgy day in Sydney. I'm up for it. Hopefully I can learn better ways of pulling the car apart and putting it back together :P
Plus it'll be handy seeing this service done. Mine's on 95k now (although I've only put 8k on it :? ) so it'll be nice to see how it's done if I do it myself (and run another dodgy day :P )
Bevan
Postby Bevan » Wed Jan 24, 2007 9:45 pm
I have made an addition to the bottom of my list... 8) :D
Craig
Postby Craig » Wed Jan 24, 2007 10:57 pm
marcusus wrote:Hopefully I can learn better ways of pulling the car apart and putting it back together
With the added bonus that if it doesn't work...it's Bevans problem! :twisted:
irwin83r
Postby irwin83r » Thu Jan 25, 2007 5:37 pm
sounds like an ideal chance to try some timing and dodgy mod experiments..
can an NB8B run on pure octane bosoter???? :P :lol:
can you shave the head with an angle grinder??
and if anyone can do some ecu remapping maybe we can see just how high the motor will rev :)
Craig
Postby Craig » Thu Jan 25, 2007 5:54 pm
:lol: :lol: :lol:
bigdog
King of the kennel
Postby bigdog » Thu Jan 25, 2007 11:46 pm
irwin83r wrote:can an NB8B run on pure octane bosoter???? :P :lol: - it works better with Octane Boooooster
can you shave the head with an angle grinder?? Scissors and a razor are safer
I don't think Bevan's tacho goes past 10000rpm.... :mrgreen:
irwin83r
Postby irwin83r » Sat Jan 27, 2007 11:13 am
guess we'll have to pull that apart too then :D
Bevan
Postby Bevan » Sun Jan 28, 2007 3:47 pm
:lol: :lol: :lol:
So I guess from these responses that a few of you are interested? I'll try and give some details soon.
ampz
Vehicle: NA6 - Turbo
Postby ampz » Sun Jan 28, 2007 7:14 pm
I will be happy to lend a hand...
I'm good with spanners, hammers and bottle openers :lol:
Huh?
KAM
Postby KAM » Mon Jan 29, 2007 12:28 pm
jules wrote:
    Idler pulley
    tensioner pulley
    tensioner spring
    OCV Orings
Hey Bevan,
OCV oil pipe washers - look at the rear of the cam cover you will see where a oil pipe from the block joins the pipe running along the top of the cam cover.
OCV Orings - When the OCV unit at the front of the cam cover is removed there are two different sized Orings which need replacing. The gasket for this unit should probably be replaced as well (I didn't as I had forgotten this when ordering the parts.
I found MX5Parts.UK cheaper than buying from Mazda even at the Club discount but they don't have the Orings, washers or the NB8B cam cover gasket or cam seals.
I can send you the part numbers and prices if you can wait as I'm on holidays in Adelaide and won't be home until 5th Feb. Probably won't get back on the this site until then either.
Silver 2001 NB8B
