No2. Guru LSD
No3. ECU
No4. DRIVE!
This is the treatment NPN's SP is getting when he returns from OS.
And please, for GOD'S SAKE, don't remove the SP badge. No-one knows what they are anyway, so no point removing it.
Boags
16bit wrote:2: upgrade to a properly design CAI
3: upgrade to a more free flow cat back system and maybe a hi flow cat.
4: upgrade your intercooler and piping
8: i thought the sp came with an lsd but if not guru as above too
Boags'MX5 wrote:16bit wrote:2: upgrade to a properly design CAI
This is an SP, not an SE.
jules wrote:No1. Suspension
No2. LSD
Then call back for a repeat prescription.
Jules
Sean wrote:T piece boost mod.
MX5-SP wrote:Sean wrote:T piece boost mod.
I think the jury is still out on the T-Piece mod. I know it's cheap...but if it was that simple to apply such a power boost then way didn't Horsley install it?
I took the safer...but much more expensive option...of a chip upgrade. I'm still suspicious of such a simple change...I think the long term consequences will appear at some stage...but then again, I could be wrong. I guess time will tell.
Regards,
Sean wrote:MX5-SP wrote:Sean wrote:T piece boost mod.
Regards,
Horsely had to provide warranty, he probably remembers back to the early days of turbo mazda's that nearly sent Mazda broke! I was sceptical at first, but to attend teh NSW dyno day and see a number of cars run on the dyno with VERY safe AFRs, and no pinging and return good power converted me.
I've owned a few turbo cars now, and have used a bleed valve on a few factory turbo's to achieve similar results, my tests werebased only on AFRs, but teh results at the NSW dyno day are hard to argue with.
Okibi wrote:
More Free Flowing Exhaust
Better turbo and bigger injectors
Users browsing this forum: Bing [Bot] and 6 guests
