Turbo install begins :) (big pics)
Uncle Arthur
Dodgy Award Benefactor
Postby Uncle Arthur » Sun Feb 25, 2007 10:58 am
mickfred
Postby mickfred » Sun Feb 25, 2007 2:13 pm
noice!
YEAH BABY!
STV
Postby STV » Sun Feb 25, 2007 3:28 pm
cant wait to see the rest of it UA!
Where is 'Home Sweet Home'?
Fatty
Postby Fatty » Sun Feb 25, 2007 4:19 pm
very good to see one of those manifolds being installed.
looking great so far!
Sean
Postby Sean » Sun Feb 25, 2007 8:27 pm
Will be good to see the results of a budget/bitsa build up and compare them to the more conventional AVO/Greddy kits.
I applaud your willingness to take on such a project! 8)
Uncle Arthur
Postby Uncle Arthur » Sun Feb 25, 2007 9:44 pm
Sean wrote:Will be good to see the results of a budget/bitsa build up and compare them to the more conventional AVO/Greddy kits.
Thanks!! :)
I've got some good help too......
Astroboysoup
Postby Astroboysoup » Sun Feb 25, 2007 10:54 pm
yeh i applaud you too.. i took the steps but couldn't follow through... one step too hard for me i must admit.
keep going
AustCars.net - It's like Facebook but for cars!
lowmiata
Postby lowmiata » Mon Feb 26, 2007 1:45 pm
Fatty wrote:very good to see one of those manifolds being installed.
Bolt on my a$$
I cant work out how bolt on requires 13mm drill bit and a 4 inch grinder!
and the dump pipe! argh what a PITA you have to take it through the engine bay!put it in befor the turbo!
doesn't make sense!
all in all though not bad for minimal outlay
EVI15 1998 to 2008
mr_rotary
Postby mr_rotary » Mon Feb 26, 2007 1:53 pm
Can you give us all a general run-down on the specs, prices etc on the installation?
jules
Guitar Hero
Postby jules » Mon Feb 26, 2007 2:19 pm
So when's the Dodgy Day Arthur?
Jules
Benny
Postby Benny » Mon Feb 26, 2007 3:58 pm
Nice shiny bits UA.
Bet you can't wait to fire her up!
JBT
Postby JBT » Mon Feb 26, 2007 9:35 pm
Looks good UA. Can't wait to see the beastie out on the road. You'll have to take me for a short run in it 8) .
Uncle Arthur
Postby Uncle Arthur » Mon Feb 26, 2007 10:41 pm
The basic kit was purchased from a fellow forumite - $1800 got me:
- TD04
- Turbosmart BOV
- SS manifold, dumppipe
- GReddy EManage Blue (piggyback) & spare 1.6 ECU and wiring harness
- 1.8 injectors
- RX7 (topmount) IC which makes a perfect sized FMIC
Other costs/items/gifts have included:
- Autometer Oiltemp gauge
- Autometer Boost gauge (yay for birthdays)
- Oilines/fittings, etc ($130)
- Silicone pipe joiners & Stainless pipe
- 2 core metalbody custom radiator
- turbo rebuild
- Mazdaspeed LSD & rebuild
- 2.5 inch hiflow cat
- wiring, hoses, etc
- clutch replacement
- other necessary servicing.....
So far the turbo budget sits (I think) around 3K all up - some parts like the LSD I bought prior to the intention to turbo, and the radiator was a necessary replacement due to cooling system issues. In the last 6months I've also done the timing belt, water pump and clutch, just to be on the safe side.
I have to wait if I need to get it dyno'd or if the Miataturbo EManage forum delivers me a suitable tune.....
Install continues this coming weekend - the initial measure up was only a small affair at the request of my RiceMaster... :D - my garage was turned into a full metalshop.....
This weekend I'll be fitting up the completed piping, and hopefully getting the dumppipe to fit properly - they obviously sized it WITHOUT airconditioning - potentially more cutting, insertion of a couple of bends, and rewelding it..... drilling the sump (oil return) routing the other hardware (water/oil lines)... etc.....
Last stage will be finishing it all up - perhaps at this stage dodgy day will be 9 March 2007. Including fitting various electronic tuning gizmos, boost sensor, loading a tune onto the EManage...... etc, and hopefully turning the key :)
Who's in???????? :D
Sean
Postby Sean » Mon Feb 26, 2007 11:00 pm
Uncle Arthur wrote:Install continues this coming weekend - the initial measure up was only a small affair at the request of my RiceMaster... :D - my garage was turned into a full metalshop.....
Who's in???????? :D
Sounds like a day worthy of looking for cheap flights...
