Diagnostic box on the SE...
Boyracer
MX-5 Encyclopedia
Postby Boyracer » Mon Feb 26, 2007 12:40 pm
Does anyone have the diagram to show which pins to short out to get the Thermo fans working..
Thanks.
CT
Postby CT » Mon Feb 26, 2007 1:26 pm
From miata.net Lou - for the NAs but it might be similarly marked in the SE. The yellow wire in the fan plug is the power wire for the fan - the black is the ground in case you want to test your fan. :)
The connection to the Diagnosis Connector goes to its “TFA” terminal. If the “TFA” terminal is jumpered to the “GND” terminal, the effect is the same as closing the Water Thermoswitch, i.e. the fan should activate if the ignition switch is on. This is a good test to determine that the relay and fan motor are working. (This test will not activate the A/C Condenser Fan.)
blackster
Re: Diagnostic box on the SE...
Postby blackster » Mon Feb 26, 2007 2:01 pm
Boyracer wrote:Does anyone have the diagram to show which pins to short out to get the Thermo fans working..
Thanks.
You have a mail, diagram pdf attached.
Previous
04' MX5 SE.
02' MX5 Classic ed.
Boyracer
MX-5 Encyclopedia
Postby Boyracer » Tue Feb 27, 2007 9:17 am
Thanks Phillip,that really helped,worked out I unplugged the fan relay during building the car and it didn't get put back in.
CT
Postby CT » Tue Feb 27, 2007 1:55 pm
Boyracer wrote:Thanks Phillip,that really helped,worked out I unplugged the fan relay during building the car and it didn't get put back in.
OMG!! Lucky the ambients were low at PI and EC. I must check mine! 8)
