Engine Damper Kit?
lowmiata
Postby lowmiata » Tue Mar 06, 2007 1:14 pm
they do work but the difference would not be noticable
your engine mounts wont wear out as quick! :mrgreen:
they doo look good in an engine bay though!
EVI15 1998 to 2008
Fatty
Postby Fatty » Tue Mar 06, 2007 1:26 pm
one of the guys on miataturbo.net fitted one and put some pictures up. he reckons it made gear changes much easier wiith his worn out old engine mounts.
Boags
Postby Boags » Tue Mar 06, 2007 3:50 pm
Group buy? :lol: Probably end up a lot less than what he is asking... I can have a look if there is any interest.
Boags
Philip Lee
Postby Philip Lee » Tue Mar 06, 2007 3:58 pm
would this fit if u have a struct brace?
Boags
Postby Boags » Tue Mar 06, 2007 4:19 pm
I would say yes, from the looks of the pictures provided there wouldn't be a problem. One would go on top of the other.
GS
Postby GS » Tue Mar 06, 2007 4:58 pm
I was unfortunate enough to have a Mitsubishi Colt as my first car. Along with a list of other problems, the engine mounts wore out after a year. Im guessing the rip snorting 1.6 had enough torque to twist the front subframe, because when i put my foot down the car would jump right and change lanes. Lift off and it would jump the other way. Being a broke uni student i put up with this for a while, and just had to remember to turn my wheel a 1/4 turn when i accelerated.
1989 NA6
Sheck
Postby Sheck » Tue Mar 06, 2007 5:42 pm
I'm running one that was suited to an R32 skyline and i modded it to fit. I'm running a turbo so it may/maynot make a diff.
I felt it was much better than before as the gearbox would move around alot during drifting which would slow down my changes alot and more often than not kill the drift - now its all sweet!!
Dave
Andrew
Postby Andrew » Tue Mar 06, 2007 7:01 pm
Did someone say bling :?:
...and its red as well woooohooooo 8)
Boags
Postby Boags » Tue Mar 06, 2007 7:22 pm
Andrew wrote:Did someone say bling :?:
Apparantly it needs slight modification for NBs, but you use the same unit...
You know you want to Andrew! :mrgreen:
Andrew
Postby Andrew » Tue Mar 06, 2007 7:47 pm
Yeah it may be good but i think i may need an igniter or two for my motor first :(
lowmiata
Postby lowmiata » Tue Mar 06, 2007 9:24 pm
Philip Lee wrote:would this fit if u have a struct brace?
nup
bolt threads on the shock top hat are not long enough for two thicknesses of metal approx 3mm each.
EVI15 1998 to 2008
kitkat
Postby kitkat » Wed Mar 07, 2007 9:43 am
How would this go with clutch shudder?
Would installing one decrease the vibration/shuddering you get or does clutch shudder not effect the engine?
honki3rider
Engine Damper Kit?
Postby honki3rider » Fri Aug 08, 2008 9:50 pm
digging up an ancient thread. :lol:
free revving the engine from the engine bay and i can see that the whole engine rocks from side to side with every rev. :shock:
by how much would an engine torque damper reduce this rocking action?
and where could i attain one for a decent price.?
how's this one: Weapon R torque damper
Sheck
Engine Damper Kit?
Postby Sheck » Sat Aug 09, 2008 6:12 pm
you can obtain a cheap one from me :D
let me know if your interested
$50
honki3rider
Engine Damper Kit?
Postby honki3rider » Mon Aug 11, 2008 5:23 pm
pm sent. :lol:
