Car wont start :(
Andrew
Car wont start :(
Postby Andrew » Wed Mar 07, 2007 4:31 pm
The last time i used it, i had to crank it a few more times before it would come to life.
Fuses look ok, has half a tank of fuel, will check the fuel pump and spark in a minute.
Anyone have any ideas :?:
CAS (does it even have one) or an igniter module :?:
It has just over 150,000km's on the clock.
Andrew
Postby Andrew » Wed Mar 07, 2007 5:26 pm
plugs are dry
lead check out ok
from what i can tell there is spark
mickfred
Postby mickfred » Wed Mar 07, 2007 5:30 pm
did you leave your lights or a light on?
YEAH BABY!
jules
Guitar Hero
Postby jules » Wed Mar 07, 2007 5:41 pm
Fuel pump?
Jules
Andrew
Postby Andrew » Wed Mar 07, 2007 5:44 pm
jules wrote:Fuel pump?
Jules
Yeah i'm thinking that may be the problem.
Just shorted GND and F/P in the diag connector and i get a click so the realy is working.
How do i tell if the pump is running or not :?:
Andrew
Postby Andrew » Wed Mar 07, 2007 5:45 pm
mickfred wrote:did you leave your lights or a light on?
Nah it cranks over fine.
Boags
Postby Boags » Wed Mar 07, 2007 5:51 pm
Jules
Can you hear the whirring of the pump when you short it? Might not be audible from the engine bay with the NB, so get someone to stick their ear to the filler with the lid off.
Boags
mickfred
Postby mickfred » Wed Mar 07, 2007 5:56 pm
well... that's me done
YEAH BABY!
Andrew
Postby Andrew » Wed Mar 07, 2007 5:59 pm
There is a high pitch noise come from the engine when the key is in the on position. When i short the fuel pump all i get is a click and thats it, no more noises from the engine bay or the fuel tank area and the first noise doesnt change.
Where is the fuel pump and how do i replace it :?: or is there another way to test it first :?:
Juffa
Postby Juffa » Wed Mar 07, 2007 6:07 pm
Bummer Andrew.
The fuel pump is in the tank. You have to pull the carpet away from the rear deck to acces it. I recently saw some info on removal and testing in the miata.net garage.
J
Andrew
Postby Andrew » Wed Mar 07, 2007 6:08 pm
Juffa wrote:Bummer Andrew.
J
Cool, been checking there and yet to find it.
NMX516
Postby NMX516 » Wed Mar 07, 2007 6:43 pm
Could it just be the battery?? I've just had similar problems in my other car, and it turned out the alternator was past its best and not charging the battery properly. It ended in tears by the roadside with a flat battery, waiting for a towtruck for 2.5hrs... Cranking an engine into life is a big drain on the battery compared to what it does while driving.
Andrew
Postby Andrew » Wed Mar 07, 2007 6:55 pm
NMX516 wrote:Could it just be the battery?? I've just had similar problems in my other car, and it turned out the alternator was past its best and not charging the battery properly. It ended in tears by the roadside with a flat battery, waiting for a towtruck for 2.5hrs... Cranking an engine into life is a big drain on the battery compared to what it does while driving.
Dont think so, it still cranks nice and fast and there is spark.
Craig
Postby Craig » Wed Mar 07, 2007 6:57 pm
What about those pesky relays etc under the bonnet? :?: :?
StanTheMan
Postby StanTheMan » Wed Mar 07, 2007 7:09 pm
when you connect the F/N & GRD .....once you put the ingition key to ther on position the fuel pump should start to hiss....... if its not....its your fuel pump. Mine has the same issue.....except that it may have an intermittent fault. But its getting replaced in a few weeks.
not sure if whacking it will help as its surronded by metal but you could try it. A $35 relay is probably worth having anyway.
once you hear the fuel pump working you will know it......pretty hard to miss once you start listening to it.
