Changing shift lever boots and shift bushes any hints?
I changed my oil in an attempt to fix my gearbox sticking after accelerating hard but no go.
So I am thinking that doing the above might help?
Is this very hard to do has anybody got any handy links or how to's they can send?
Thanks as always
Thanks as always
SOLD - Red NA - NB wheels, Lock Stewart, fluffy dice
- green_comet
- Car Detailing Guru
You might want to change the oil in your gearbox turret while you are at it.. Remove the centre console, and rubber boots (replace if they are split), and pull out the shifter. Pump the old oil out and replace it with some new stuff... Its a pretty easy job, and should help with your problem..
Try these two links, scroll down on the first link.
http://www.miata.net/garage/trans/everything.html
http://www.miata.net/garage/shiftboot.html
Ryan
Ryan
Yeah it only happens going up hill which i think is odd. If i am going downhill hard it doesn't happen.
I had my hand on 2nd accelerating hard up hill and I could feel it move further towards the read of the car as it accelerated (if that makes sense)
Ill give this a go as its cheaper than a new gearbox.
- CT
- SuperMazdaKart
- SuperMazdaKart
And one from me on this topic if I may...
I changed my shift bush over to a new brass one over the weekend (shift much better now), but buggered if I could get the gearknob off, both top and bottom boots are split and knackered and need to be replaced - what's the story, am I just too wimpy?
Cheers, Dave, 1990 NA6
Via est vita.
Via est vita.
davamb wrote:And one from me on this topic if I may...
Is there a grub screw holding it on? If not then yep wimpy it is
Mazda Tribute - its a boat
Coming - Jayco Eagle wind up camper - woo hoo
Ex cars 2007 NC LE Radiant Ebony, 1990 Eunos Neo Green LE
- meanmx
Wimpy....Sorry
Ben
Ben
2014 VW Mk7 Golf R
- TieNN89
green_comet wrote:You might want to change the oil in your gearbox turret while you are at it.. Remove the centre console, and rubber boots (replace if they are split), and pull out the shifter. Pump the old oil out and replace it with some new stuff... Its a pretty easy job, and should help with your problem..
Ryan
do you put the gearbox oil in there or is it different
and how much do you put in there?
- Vehicle: NA6 - Turbo
Davamb you need to take your gear lever out and take your gear knob off. Then the two gear boot seals need to slide off, moving from the bottom to the top. Add some grease on to your gear lever first as this will help the rubber move. Then to install the new gear boot seals simply grease up the gear stick then slide the two boots down the shaft... I recently replaced mine and this worked well.
- TieNN89
