Hi guys i have had a look at a few other posts on this topic and also tried the suggested ECU reset thing but my car continues to idle at 1200rpm with the idel control screw all the way in so its really at about 1500rpm when the screw is in a normal position.
Any advice on what to try next would be much appreciated.
Clint
Informous High Idle
- Garry
Check that the throttle plate is resting on it's stop and look for vacuum leaks around the intake. Your idle speed controller may be stuck open or if you have a NA6 the cold idle valve thingo on top of the inlet manifold may be stuck.
There's a few things to get you going.
- Bevan
- jules
- Guitar Hero
