Oxygen Sensor - problems
Fatty
Postby Fatty » Fri Jun 01, 2007 11:10 pm
they are cheap enough, i think mine was about $80. i reckon it's a good idea to replace it if you have any doubts
Fatty
Postby Fatty » Fri Jun 01, 2007 11:18 pm
oh and that link is bloody excellent! thanks
NMX516
Postby NMX516 » Sun Jun 03, 2007 3:17 pm
Does anybody here happen to know if this diagnostics test would be the same for an NB8A?
NMX516
Postby NMX516 » Sun Jun 03, 2007 3:31 pm
Bugger! Thanks anyway Slugoid
Wuey
Postby Wuey » Sun Jun 03, 2007 6:10 pm
Slugold, thanks for the heads-up on the part number. I bought the same one from Repco for the same price today.
I checked my sensor a couple of months ago with no error code. Did the same test today and found code 17 i.e. oxygen sensor(output not changing). Lately, I also notice my car seems not to accelerate as strongly as before and it has been gulping fuel like I own an oil well.
I don't know how you could have changed the sensor in such a short time. That place is cramp. When the exhaust was still hot, I touched the sensor base with a candle to weep some wax on its thread. I then sprayed some WD40 onto the sensor base and the little bolts on the heatshield. When the motor was cool enough, I removed the air box and the heatshield. I used a big shifter to undo the sensor. It came off real easy.
The supplied heat shrink is a tad too big so I slipped a smaller diameter heat shrink before slipping on the bigger one.
Once everything was in place, I disconnected the battery to reset the ECU. After a short drive, I rechecked the code and all was well. There is a noticeable improvement in acceleration now. I'm anticipating better fuel consumption too.
Image 2004 SE
SuperMazdaKart
Postby SuperMazdaKart » Sun Jun 03, 2007 6:17 pm
interesting, when i replaced mine with the universal Bosche the car lost some of it's revviness... maybe the prior sensor was actually still good & a genuine OEM so delay was a lot less then any aftermarket version?
adamjp
Postby adamjp » Sun Jun 03, 2007 8:15 pm
NGK make a complete replacement unit, right down to the correct plugs to fit into the wiring loom without drama. Sold under the brand of NTK.
Last time I costed one it was $80 walk away for a single wire NA6 unit.
Part number OZA401-E20 with the connector, OZA624-E1 for universal without the connector (this one was probably a bit cheaper).
Adam
jules
Guitar Hero
Postby jules » Tue Jun 05, 2007 12:18 am
adamjp,
That's a great find for the price.
Jules
STV
Postby STV » Tue Jun 05, 2007 9:12 am
for the NB mob out there.
you can get an OBD scanner from Jaycar for $129.. not real cheap, but if you do a few repairs on recent cars, it might be worth it, or perhaps if a few same state folk wanted to use one they could all chip in or something??
STV
Where is 'Home Sweet Home'?
Garry
Postby Garry » Tue Jun 05, 2007 9:45 am
OBD2 first came to Aus in the NB8C cars, ie 2003 onwards. However the ECU checking thingo that your friendly Mazda dealer has will pick up more faults than the flashing LED will pick up on pre OBD2 NB's.
Craig
Postby Craig » Tue Jun 05, 2007 3:03 pm
Garry wrote:OBD2 first came to Aus in the NB8C cars, ie 2003 onwards. However the ECU checking thingo that your friendly Mazda dealer has will pick up more faults than the flashing LED will pick up on pre OBD2 NB's.
Apparently the Mazda "ECU checking thingo" cost about $20,000 dollars! :shock:
JBT
Postby JBT » Tue Jun 05, 2007 3:07 pm
Get me two of them :mrgreen:
Garry
Postby Garry » Tue Jun 05, 2007 3:14 pm
Apparently the Mazda \"ECU checking thingo\" cost about $20,000 dollars!
You'd hope it would pick up more faults than the flashing LED then wouldn't you. :D
A BMW mechanic was showing me how the BMW \"ECU checking thingo\" works once. It plugs into the car diagnostics plug and checks ALL the electrical circuits, even little things like the horn if required. It can activate all the electrical circuits from the comforts of the operator console and is so clever it can even determine if a light globe is blown. It was a pretty impressive bit of gear but had a very impressive price tag to match.
Craig
Postby Craig » Tue Jun 05, 2007 3:33 pm
True but I'd want it to make a darn good coffee too for 20K! :mrgreen:
Mind you popping into Benny's home or work for coffee is always free! :twisted:
Benny
Postby Benny » Tue Jun 05, 2007 6:10 pm
Craig wrote:True but I'd want it to make a darn good coffee too for 20K! :mrgreen:
You obvioulsy haven't been drinking much coffee lately Craig.
