recommended oils for street use
JBT
Postby JBT » Tue Jun 12, 2007 9:12 pm
Castrol and Penrite will both be good.
Postby Okibi » Tue Jun 12, 2007 9:17 pm
Putting oil on the street is dangerous. :oops:
Oil for engine use - Mobil1is the great but there's cheap oils that do the job. It depends which engine you've got an how many kms she's run.
gearbox - Redline MT90 (or MTL if you're that way inclined)
and diff - Redline 75W90 (depends what diff you have)
StanTheMan
Postby StanTheMan » Tue Jun 12, 2007 10:13 pm
GTX3 would prolly be ok. If you have noisy lifters on start up......Try the mobil 1. Whenever mine get noisy its time to change anyway.
JBT
Postby JBT » Tue Jun 12, 2007 10:25 pm
Castrol seem to think it's fine.
NMX516
Postby NMX516 » Tue Jun 12, 2007 11:24 pm
I know this will probably open a can of worms, and some people will disagree, but full synthetic oils aren't \"necessary\" for these engines, and can often do more harm than good.
Let me explain :) Full synthetic oils such as mobil 1 are designed for engines built to extremely fine tolerances. An MX5, and most other mass produced cars aren't built to ultra fine tolerances, so don't need such a thin oil. Thin oils can just glaze the bores, and cause oil consumption as a result. My other car lived on a diet of mobil 1 for 40,000kms (changed every 5000km) before requiring new rings and re-honing of the cylinders. This was 40,000kms after a full rebuild.
Full synthetics are great for the latest hi-tech engines, made from trick alloys, but otherwise can be a very false economy. I wouldn't use a full synthetic in an MX5, I use a semi synthetic...
just my 2c worth :)
JBT
Postby JBT » Wed Jun 13, 2007 7:37 am
I agree with NMX516 regarding synthetics. There are quite a few older MX-5s around here using oil now because the owner changed to synthetic.
what would you guys recommend for short trips
Just change the oil more often as this is a severe condition
dont want to use magnatec, imo it'll attract lil metal particles too
:? All oil collects small metal particles. The oil filter collects them. The \"theory\" behind Magnatec is it sticks to the metal parts of the engine.
Boost
Postby Boost » Wed Jun 13, 2007 10:18 pm
I just changed my tranny & diff oil the other day. Boy does it make alot of difference. Shifting gears is alot easier and smoother now. I use to have alot of troubles getting into first especially when the cars cold, now it slips right in there without a problem. :mrgreen:
none as yet - looking for a white NA8
Postby Okibi » Wed Jun 20, 2007 9:17 pm
You have the 1.6 so i'd say it's the BKR6E-11 or BKR6EIX-11 for the Iridium IX.
For the 1.8 it's the BKR5E-11 and BKR5EIX-11 for the Iridium IX, spark gap is 1.1
Postby Okibi » Wed Jun 20, 2007 9:19 pm
Geoffro
Postby Geoffro » Tue Jul 10, 2007 10:10 am
lam.666 wrote:what spark plugs does everyone use
i can see NGK has 3 types
bkr5e-11
bkr6e-11
bkr7e-11
which one do i pick?
With NGK the higher the number eg, BKR7E-11 the colder runing the plug is.
geoffro
White NA extractors,Unifilter pod,strut brace Racing Beat chromed roll bar, 17"x7" chrome alloy wheels Selby lowered coils.LSD
green_comet
Car Detailing Guru
Postby green_comet » Tue Jul 10, 2007 11:47 am
I used Motul 300V Chrono in my car a couple times, not a bad oil but nowhere worth the money they charge for it.
Lately i have been using Nulon Synthetic hi-tech fast flowing 10w-40, and i cant fault it.. The engine feels much more responsive running this compared to the Motul. I have tried soo many different types of synthetic oils, Mobil 1, Motul etc.. and this oil is the best one i have used to date.. Priced at about $65 for 5l, its quite cheap too.
http://www.nulon.com.au/products.php?productId=syn10w40#
