Cheap CAI
GP wrote:Does the air come from the cabin? If so doesn't it make the cabin stink of petrol and your ears ring from the induction noise?
No it dont, the hole in the "firewall" exits above the cabin but below the windscreen. there is some plastic stuff covering the area above the exit point.
Your can still hear the induction though
Mazda Tribute - its a boat
Coming - Jayco Eagle wind up camper - woo hoo
Ex cars 2007 NC LE Radiant Ebony, 1990 Eunos Neo Green LE
It is getting the air from the same place as the Loch Stewart, Mania and most other CAIs, and that is the area above the firewall and below/in front of the windscreen. The cabin does get it's air from that area, however I am not aware of anyone reporting fumes in the cabin because of this?
J
Been doing a bit of research and came across this which is probably old news to all of you but new to me
http://autospeed.drive.com.au/cms/article.html?&A=0892
As Jules said leaving the airbox in would seem to be a waste of time after doing all the other work.
What are peoples thoughts on the \"Simota Super Power \" filter that's mentioned, They have them at Mania for $75.
Graham
The Simota Heat Sheild Filter Is already sealed and I was wondering what peoples thoughts on this filter are.
The air will never be cold but the air under the bonnet is a lot hotter than in front of the windscreen so I think this is a great mod.
He also mentions a larger AFM off a 86-88 RX7, Are these available? Very Expensive?
Graham
- Matty
Steve 818 wrote:GP wrote:He also mentions a larger AFM off a 86-88 RX7, Are these available? Very Expensive?
You could probably pick one up from a wreckers but I'm pretty sure that Matt didn't end up using the bigger AFM as he couldn't get a happy compromise with that setup.
Now that the Jaycar DFA is available though, you could probably get that setup working well but it will involve more money and some tuning.
What he said. Just get a programmable MAP-based ECU and be done with it.
- Grumpy
- Boags
GP wrote:What he said. Just get a programmable MAP-based ECU and be done with it.
WTF is that. Something tells me that it's not an aircleaner
If it hasn't got carbs and points I don't know what it is
He is suggesting you buy a replacement ECU which will allow you to tune via a MAP (Manifold Absolute Pressure) Sensor. These take a pressure reading and RPM and add fuel. They DON'T use an AFM (air flow meter - what you have now) which is quite restrictive to airflow.
Hence the comment about turning a $2 mod into a $1500+ project.
Boags
- ampz
- Vehicle: NA6 - Turbo
