Resetting ECU
deez
Resetting ECU
Postby deez » Mon Jun 25, 2007 3:48 pm
How do you go about resetting the ECU on an NA6? What are the advantages/disadvantages of performing an ECU reset?
Cheers guys.
89 Eunos Roadster
Fatty
Postby Fatty » Mon Jun 25, 2007 4:39 pm
only reason to re-set ecu as far as i know, is to clear any fault codes. simplest way that i know of is to disconnect the battery and step on the brake pedal for about 10 seconds.
StanTheMan
Postby StanTheMan » Mon Jun 25, 2007 5:01 pm
What happened to connecting GND & TEN in the diagnostic box?
ampz
Vehicle: NA6 - Turbo
Postby ampz » Mon Jun 25, 2007 5:38 pm
Nothing... :mrgreen:
You use GND + TEN to set your timing and base idle speed.
You can permanently reset it by dropping it in water though :shock: :P
Huh?
Postby bruce » Mon Jun 25, 2007 5:42 pm
Ya reckon loading Vista will make my car quicker?
ampz
Postby ampz » Mon Jun 25, 2007 6:04 pm
:lol:
Huh?
Bevan
Postby Bevan » Mon Jun 25, 2007 10:21 pm
Fatty wrote:only reason to re-set ecu as far as i know, is to clear any fault codes. simplest way that i know of is to disconnect the battery and step on the brake pedal for about 10 seconds.
I haven't heard of the brake pedal thing before, as there's no power going to anything, so it could flick any switch or anything. But yes, disconnecting the battery is the only way to reset it. Just disconnect it for a few minutes. :)
GP
Postby GP » Tue Jun 26, 2007 10:49 am
Sorry to go off topic.
Do you connect these 2 terminals together and then turn the screw in the throttle body to set the idle?
I've been scewing this thing in and out without anything happening.
Graham
Richee
Postby Richee » Tue Jun 26, 2007 11:48 am
Try this - cured my idle drop issues
http://www.miata.net/garage/KnowYourCar/S7_Idle.html
Mazda Tribute - its a boat
Coming - Jayco Eagle wind up camper - woo hoo
Ex cars 2007 NC LE Radiant Ebony, 1990 Eunos Neo Green LE
Benny
Postby Benny » Tue Jun 26, 2007 12:07 pm
bruce wrote:Ya reckon loading Vista will make my car quicker?
Maybe, but as you don't have a Start button in your car, you won't get it going and if you do, you won't be able to stop it.
Anyway, where would you put the USB plug?
Sean
Postby Sean » Sun Jul 01, 2007 1:17 pm
Damn MAC Converts :lol:
