Uncle Arthur
- Dodgy Award Benefactor
- Location: Doesn't matter where I'm from-it's that your daughter is with me that's the biggest concern :D
Postby Uncle Arthur » Sun Jul 01, 2007 7:43 pm
Justin K wrote:Hi Guys,
Can anyone tell me the correct technique for removing the oil filter from a na mx5. can't get at anything!
Any help would be greatly appreciated!
Justin
from the drivers side - stick your left hand down between the engine and the chassis - reach down till you feel the filter.
Now - reach your right hand down around the front of the engine - below the intake until your hands meet at the filter. Now turn the sucker anticlockwise as hard as you can. You may need to put a rag on the filter for grip.
It should just turn off. When you replace the filter only turn it until it is hand tight - do not screw it on to all buggery.
dv8one
Postby dv8one » Sun Jul 01, 2007 10:59 pm
Buy a K&N filter they have a nut on the back you can fit a socket on so next time you should have no issue!
SuperMazdaKart
Postby SuperMazdaKart » Sun Jul 01, 2007 11:18 pm
might have to stab it with a screwdriver
Postby manga_blue » Mon Jul 02, 2007 12:44 am
Really hard to decribe but ...
I've got a filter removal tool. It's a 150mm long square tube which has a loop of about 40mm seat belt type material attached. One end takes a standard 1/2 inch socket drive. With a few socket extension pieces I can get the belt wrapped around the filter and use them to tension up the belt around the filter by hand. Need to jack up the car and remove the driver's side front wheel. The extensions run through a small gap above/behind the upper control arm bushes. Then I put a ratchet on the extensions and give it everything I've got. Usually crushes the filter, but it comes off. Takes me less than 5 minutes now, first time took me two hours.
I've tried self-clamping tools before but they always slip. If it's a Mazda filter then I believe Mazda sell a socket which fits over it, but I've never seen it.
The rumour is that the K&N filters are crap compared to Mazda OEMs.
Spranga
Postby Spranga » Mon Jul 02, 2007 9:46 am
MX5 Mania sell the wrench which fits onto the factory filter and when you use this it is a cinch. The wrench only costs about $15 but it saves heaps of *&(#%^)^(*^_ing. I also find it is easier if you jack the car up and remove the front drivers wheel. It has taken a few oil changes but I think I have got it down to a precise art now
Good luck
Dan
deez
Postby deez » Mon Jul 02, 2007 11:38 am
Lesson of the day....stick to using genuine Mazda filters
Last one I had was a Ryco something or rather. Took 2 people half an hour, with the car jacked up, to get the damn thing out.
89 Eunos Roadster
Garry
Postby Garry » Mon Jul 02, 2007 12:00 pm
For a bit more room you can remove the alloy support that holds the intake to the block.
SuperMazdaKart
Postby SuperMazdaKart » Mon Jul 02, 2007 1:32 pm
or do what dv8 did & swap out the whole engine for another
Uncle Arthur
Postby Uncle Arthur » Mon Jul 02, 2007 1:56 pm
I tnever takes me more than 5 minutes to remove an old oil filter - by hand - but then again I never overtighten them in the first place - only tighten them using light hand pressure - when my hands will slip slowly on the filter casing as I'm doing it up, then it is tight enough.
ampz
- Vehicle: NA6 - Turbo
Postby ampz » Mon Jul 02, 2007 8:21 pm
Yeah stab it!
To hand tighten/loosen easier wrap some sandpaper around it
Huh?
JBT
Postby JBT » Mon Jul 02, 2007 10:35 pm
You can also reach it through the right wheel well with the right wheel removed.
Andrew
Postby Andrew » Mon Jul 02, 2007 11:14 pm
JBT wrote:You can also reach it through the right wheel well with the right wheel removed.
...or get one of these -
Sean
Postby Sean » Sat Jul 07, 2007 6:45 pm
Spranga wrote:MX5 Mania sell the wrench which fits onto the factory filter and when you use this it is a cinch. The wrench only costs about $15 but it saves heaps of *&(#%^)^(*^_ing. I also find it is easier if you jack the car up and remove the front drivers wheel. It has taken a few oil changes but I think I have got it down to a precise art now
Good luck
Dan
I got a similar or possibly the same tool, I actually purchased mine from the mazda dealership and it had a mazda part number, so if you're not in sydney and cant get to mania, you can probably get one from the local mazda spare parts shop.
Garry
Postby Garry » Sat Jul 07, 2007 9:14 pm
Ford used to sell the tool as well. I got mine from a Mazda dealer for a bargain price of $9.90. It must be the cheapest part they sell.
Uncle Arthur
Postby Uncle Arthur » Sat Jul 07, 2007 9:32 pm
Garry wrote:Ford used to sell the tool as well. I got mine from a Mazda dealer for a bargain price of $9.90. It must be the cheapest part they sell.
I don't think I've ever needed a special tool for doing an oil change.......
No - in fact I am certain I've never needed one....
Just do it by hand - much easier than mucking around trying to fit a tool into that small amount of space and cursing when it catches on things or is difficult to manipulate.....
