stock 5 speed power handling
16bit
Vehicle: NB8A - Supercharged
Postby 16bit » Wed Jul 04, 2007 11:02 am
Does anyone have a rough figure of how much the stock 5speed box from an nb8a can handle? Or is it a case of driver style and condition of the box?
kula
Postby kula » Wed Jul 04, 2007 12:26 pm
id say about 180rwkw is still just ok, any higher starts treading the fine line.
16bit
Postby 16bit » Wed Jul 04, 2007 1:13 pm
perfect!
Sheck
Postby Sheck » Wed Jul 04, 2007 6:18 pm
depends how you drive it, i broke 2 5speeds at about 140rwhp, one only lasted one drift event, the other a couple.
6 speed is copeing well so far @150hp soon to be more..
Dave
Postby Okibi » Wed Jul 04, 2007 6:50 pm
Both Ian and Les's NA6's are making around 200kw.
Les's 17 year old box is still fine.
Ian's is more of a race car with an aggressive diff and he finally broke his 17 year old gear box this year.
His Kaaz diff didn't last any where near as long. :lol:
Insurgence
Postby Insurgence » Wed Jul 04, 2007 7:36 pm
Sheck wrote:depends how you drive it, i broke 2 5speeds at about 140rwhp, one only lasted one drift event, the other a couple.
Dave
is it difficult to switch 6/5 speeds between cars (e.g. are the mounts similar?)
NB8A
Blue94t
Postby Blue94t » Wed Jul 04, 2007 9:34 pm
I popped 5th gear with around 160rwkw.
That was a full throttle roll on from 80kmh - bang. Pulled out to overtake a truck. No idea of the history of the box, had just bought the car.
The new box is fine but I don't try to shift too fast because it can baulk.
Jake
Sheck
Postby Sheck » Fri Jul 06, 2007 8:26 pm
6 speed is an easy install, just bolts up for the most part. One bolt on the startermotor wont go in, but it has two any way, and you'll have to make up some plugs for the nutral switch and reverse switch. But thats a pice of cake!
Dave
PSI-JET
Postby PSI-JET » Sat Jul 07, 2007 1:50 am
Blue94t wrote:I popped 5th gear with around 160rwkw.
Accelerating hard in 5th to overtake can cause that even with probably half that power.
Fuzzlet
Postby Fuzzlet » Sat Jul 07, 2007 2:18 pm
I've nearly destroyed 3rd gear in my 5spd....apparently the 6spd from an SE has stronger gears
