leads and plugs
- Ajay
leads and plugs
hey guys..
where is the best place to find YELLOW coloured leads (preferably better performance ones) and also Iridium PLugs..
and whats the $$$ for these roughly
Thanks in advance
Ajay
Thanks in advance
Ajay
- Boags
eBay for iridiums!
I got my leads from QLD ignition leeds. They are high performance 9mm leads and they did yellow. They have a template and could post a set to you if you want.
Queensland Ignition Leads
1560 Anzac Ave Kallangur 4503
(07) 3886 5700
Fax (07) 3886 5711
Mobile Service 0416 366 486
Boags
(07) 3886 5700
Fax (07) 3886 5711
Boags
- Ajay
- Ajay
- irwin83r
mx5_boy wrote:oh and buy the way iridiums are the good plugs for lasting a long time arent they?.. not platinums..
Ajay
is what they say yeah
i got yellow leads from repco about a year ago for 110 think they were top guns
- Geoffro
Ajay
No the other way around, platinums last 80000k's the iridiums are a performance plug.
geoffro
White NA extractors,Unifilter pod,strut brace Racing Beat chromed roll bar, 17"x7" chrome alloy wheels Selby lowered coils.LSD
- Sean
I'm still yet to find any magical spark plugs...
As long as you have the right temp and gap you sholdn't be having problems with the good old $3 NGKs.... And at $3 you buy a whole lot of plugs before you're up to the cost of any of the supposedly better ones.
- Garry
What Sean said. The platinum ones are great for those stupid cars that need to be half disassembled to get to the plugs. A plug change in an MX5 is a 10min job. I'd rather buy the cheapies and replace them at regular intervals and pocket the change for other more worthwhile pursuits.
- Sean
They are popular amongst the guys in formula V racing too, I assume for similar reasons ie one fails the next takes over.GP wrote:They are for oil burners, Only 1 will spark and when it fouls 1 of the others should take over.
- pcmx5
- Vehicle: ND - 2
kula wrote:i run the bosch 4 prong jobbies, and it might have been placebo effect, but i think i noticed a little more mid range torque..
I did two back to back runs at a club dyno day a couple of years ago with old plugs and then the Bosch 4 prong ones and LOST 1 kw!!
I can't rember what the torque figs were and they may have given a better spread of torque or more torque but i was a bit miffed at the time as they weren't cheap!!!
Peter
- Sean
- pcmx5
- Vehicle: ND - 2
Sean wrote:Is 1kw really measurable? I mean heat soak could easily account for 1kw
It was 1.6 or something and it certainly wasn't an improvement!!!!!!!
However I withdraw this remark on the ground that it is technically inadmissable!!!
Peter
Users browsing this forum: Bing [Bot] and 6 guests
