I Am A Spannerhead!!!!! - Seeking the forum's help
lowmiata
Postby lowmiata » Thu Jul 19, 2007 3:45 pm
saboteur wrote:Are you ready for a three day engine swap? :lol:
what are you going to be doing for the other two days? :shock:
EVI15 1998 to 2008
Uncle Arthur
Dodgy Award Benefactor
Postby Uncle Arthur » Thu Jul 19, 2007 3:59 pm
Beer and wingz :D
Benny
Postby Benny » Thu Jul 19, 2007 5:13 pm
That's rotten luck Uncle.
Don't feel so bad about it though, many have done much worse, like a friend of mine doing his first oil change and after undoing the sump plug and draining the engine, decided it would be a good idea to start the engine and give it a big rev to get rid of all the old oil.
BIG MISTAKE!!!!
The engine was fried within seconds, and in those days, a new V8 engine cost a lot more than a good used MX-5 engine costs today!
timk
Postby timk » Thu Jul 19, 2007 5:13 pm
Uncle Arthur wrote:
lowmiata wrote:what are you going to be doing for the other two days? :shock:
Beer and wingz :D
Hey I like the way this man thinks!
AJ
Postby AJ » Thu Jul 19, 2007 5:16 pm
Uncle Arthur wrote:
AJ wrote:give me a hoi if you need the truck to do a pickup mikey 8)
Thanks AJ.
I'll be following up with Richard to see what he's got available and what will fit - I reckon I'll come out of this with a bill less than $800 incuding beer and wingz.
And a newer motor, and the chance to do more polishing. :mrgreen:
not to mention the opportunity to build a proper turbo engine outta the old one :mrgreen: ................ :? jen doesn't see this right???.........i'll not get slapped around or anything next time she sees me........RIGHT??? :shock: :lol:
XMX5 Rogues
NMX516
Postby NMX516 » Thu Jul 19, 2007 6:46 pm
Well I'll be willing to lend a hand if required UA... :)
As for what might have happened, it could have bent a valve and jammed it open which would stop the cam, and engine turning. It might be worth pulling the head off first to see if you could get away with just some head work... On the cylinder head I mean, I won't comment on the other head which needs work :lol: :P :wink:
Uncle Arthur
Postby Uncle Arthur » Thu Jul 19, 2007 6:55 pm
NMX516 wrote:Well I'll be willing to lend a hand if required UA... :)
That is to be my first efforts.......
sabretooth
Postby sabretooth » Thu Jul 19, 2007 7:18 pm
So who's bringing the drinks? Anyone bringing water? :P :roll:
Uncle Arthur
Postby Uncle Arthur » Thu Jul 19, 2007 7:19 pm
sabretooth wrote:So who's bringing the drinks? Anyone bringing water? :P :roll:
Why bother? - I've got an engine full :D
Postby Okibi » Thu Jul 19, 2007 7:33 pm
AJ wrote:...the opportunity to build a proper turbo engine ...
Gonna polish the head? :mrgreen:
Boags
Postby Boags » Thu Jul 19, 2007 9:21 pm
Oh no!
Let me know when you need a hand, I'll be there!
Boags
adamjp
Postby adamjp » Thu Jul 19, 2007 9:59 pm
In a slightly more expensive way than intended, the water in the inlet trick is cleaning UA's engine :lol:
I mean, where else do you get to 'clean' an engine with water and take 100k kms off it's life?
Still don't think I will try it though. :D
Adam
OMY005
Postby OMY005 » Thu Jul 19, 2007 11:25 pm
I'm able to give a hand. Do you have a date yet? If it is just a bent rod maybe you could replace it by just pulling the sump off? You could use my parents shed where we did red5's motor swap if you want?
Andrew.
Previously, White 95 NA 1.8 Hard Top,Stock standard
Now, 2016 Fiat 500x, 2014 Fiat 500, 2015 ND GT 2.0
Abyss
Postby Abyss » Fri Jul 20, 2007 10:56 am
I hope it was from your rainwater tank, internal cleaning of engines isn't allowed under level 5 restrictions! :D Wouldn't want to cop a fine on top of all this! :mrgreen: :mrgreen:
10AE #5522, Blue, the only colour to have. Every K over is a thriller
Uncle Arthur
Postby Uncle Arthur » Fri Jul 20, 2007 11:20 am
Of course it was - I was trying to wash contaminants OUT of my motor - not put all the gunk from Brisbane's water supply back in.....!!!!!!! :shock: :mrgreen:
