Power Limits of Torsein Diff
- Fuzzlet
My clubman still has its original diff in it, and I was wondering if anyone knows what the power limit of the Torsein is
- blackster
Re: Power Limits of Torsein Diff
Fuzzlet wrote:My clubman still has its original diff in it, and I was wondering if anyone knows what the power limit of the Torsein is
If anyone would know i guess it would be mania, im sure daniel has seen his fare share broken one's and hence would know what kind of limit they would handle.
You probably thought of that though and are hopeing that someone would provide a quicker answer on here?
Perhaps this diff/rubber will curtail and handle the power your beasty is putting out.
Previous
04' MX5 SE.
02' MX5 Classic ed.
04' MX5 SE.
02' MX5 Classic ed.
- Benny
Power limits of Diff
I personally would have thought that the power limit would have been just before the diff broke.....
sorry.....
sorry.....
- Sean
I think luck and age are just as important.
My car broke a 1.8 diff woth around 100rwkw, but then the one that was in it when I sold it had lasted quite some time woth a little bit of abuse at the drags.
Steve gosbee has been making around 240rwkw in his without issue too.
- Fuzzlet
Ive spoken to the guys at mania, and when given a sudden hit with power (eg drag racing, burnouts, clutch kicking), the torsens aren't that great....
- Vehicle: ND - 2
Sean wrote:I think luck and age are just as important.
Sean , Steve isn't running a mx diff , I last heard it had a S3 Rx7 in it could be wrong though all here say
BJ
Playing with BOOST will smoke your tyres!!!
NO LONGER MINE sob sob
- Sean
bjones wrote:Sean wrote:I think luck and age are just as important.
BJ
I'm fairly sure it'sgot an MX5 one in it agian now. Previously had a S4 or S5 rx7 one.
I believe this is a standard NA diff, running behind a B6 engine with 19psi boost..
Looks like sometimes the diff is much stronger than the whole assembly that supports it.
(courtesy of miata.net at http://www.miata.net/motm/2007/max.html)
- Bevan
- StanTheMan
- ampz
- Vehicle: NA6 - Turbo
