What are the major costs of going turbo?
Bevan
Postby Bevan » Thu Aug 02, 2007 2:28 pm
3 major points from this thread:
a) I'm a boofhead
b) Buy an SE
c) I'm a boofhead
Can we make this a sticky? :lol:
Thanks guys, I love you all... :mrgreen:
Craig
Postby Craig » Thu Aug 02, 2007 7:01 pm
Bevan wrote:3 major points from this thread:
a) I'm a boofhead
b) I'm a boofhead
c) I'm a boofhead
:lol:
Brett_MX5
Postby Brett_MX5 » Thu Aug 02, 2007 7:55 pm
Fuzzlet wrote:Yep....I've failed 4 emissions tests so I've given up, returning the clubman to stock and selling it
Serious ?? Damn shame if you are having to do that
Bloody RTA :evil:
And if you can afford the changeover price Bevan buy an SE or SP
"You tried your best and failed miserably,
The lesson is, never try"
-Homer Simpson
Postby Okibi » Thu Aug 02, 2007 8:05 pm
For the cost of modding an SE to make good power, you could put an AVO kit a motec, a PWR etc and jump though lots of hoops.
Then do your best to not be raped by the insurance companies.
Just get an SE ya boofhead; I will officially be jealous :mrgreen:
Craig
Postby Craig » Fri Sep 14, 2007 7:10 pm
a) I'm a boofhead
b) Buy an SE
c) I'm a boofhead
Yep, you'd be a boofhead !! :oops:
That's our Bevan! :lol:
Blue94t
Postby Blue94t » Fri Sep 14, 2007 11:29 pm
Budget $10k if you want a good reliable setup that will handle track time. For this though you should be able to get an Alloy radiator and replace all the little things like radiator hoses and other stuff that will be under greater thermal loading. It can be done a lot cheaper bit all depends on the results you are looking for.
Jake
Sean
Postby Sean » Thu Sep 20, 2007 7:41 pm
Fuzzlet wrote:
Boags'MX5 wrote:Don't forget the hoops that Fuzzlet is jumping through to pass the emissions tests... Lots of $$$ there - unless you live in QLD. :lol: :mrgreen:
Boags
Garry wrote:Just spend $10K and buy an SE, it's much easier.
Exactly what I've done - all the goodies from the white car will be put into the SE
Seriously Bevan, the RTA emissions test is so bloody hard to pass. You would be much better off upgrading to an SE, not just because everything is already done for you, but if you get checked for defects, you will be covered by the factory engineering, adding a bit more boost wont involve getting a major retune....that and the fact that u can spend 6k turboing your car, and it'll still only be work 24k....with an SE, it'll cost a little more than turboing your current car, but it'll be worth that much, the insurance on a modified SE is less than a turbo'd older model (the insurance on my SE is less than my clubman with a turbo....SE is 3 years old, clubman is 13....go figure)
I dont get it mate, there are plenty of modded cars, including MX5s that can pass emissions - There are even a few tuning specialists who will specifically tune the car to pass emissions...
As for the SE, you are NOT covered by factory emissions, the RTA can demand any car, modified or not, to pass the IM240 test (this is the same inservice test you'd be trying to pass with the clubman). If teh SE has poor emissiosn it's just as simple for the RTA to bump your rego on it so be careful, it's a lot of money to spend on a car to find out the RTA are pulling your rego cause you can't comply with emissiosn requirements.
Rob E
Postby Rob E » Thu Sep 20, 2007 9:09 pm
Fuzzlet, who did the tuning for you pre emmissions test/s???
Fuzzlet
Postby Fuzzlet » Thu Sep 20, 2007 9:17 pm
Mania tuned the car, however Dave kept trying to tune it to make power and pass emissions, I could never get him to do a tune that was purely for passing the emissions test
Rob E
Postby Rob E » Thu Sep 20, 2007 9:45 pm
Fuzzlet wrote:Mania tuned the car, however Dave kept trying to tune it to make power and pass emissions, I could never get him to do a tune that was purely for passing the emissions test
Dissapointing :( I tend to agree with Sean here. A second opinion would have been worthwhile.
Sean
Postby Sean » Thu Sep 20, 2007 11:42 pm
No disrespect to Dave, but he's not had a dyno or been tuning that long, I'd be trying someone like Matt @ Hitman or the guys at Ultratune in Brookvale - Both have tuned quite a few cars through emissions, Ultratune brookvale specialise in it!
Once it's passed, save the tune, then get Dave or your chosen tuner to rip it up and tune for power again.
Sean
Postby Sean » Fri Sep 21, 2007 12:35 am
More info here:
http://www.aus-cartalk.com/viewtopic.ph ... 028#345028
At the end of the day though, this picture sums up life of a modified car owner...
Blue94t
Postby Blue94t » Fri Sep 21, 2007 10:00 am
At least you guys don't have to pay for the test up in NSW.
I think I need to contact the EPA and find out if an interstate test is admissable.
Jake
Mactype
Postby Mactype » Fri Sep 21, 2007 10:26 am
Not sure if your still pursuing this but Dave at Silverwater Auto Services is the tuning guru. He's helped out both my mates who have put both hyabusa powered clubmans and supercharged Honda engined Elises through emissions testing.
Did you have a brand new, high quality cat fitted as close to the engine as possible? My mates had problems with the busa with fuel vapour leaking out of the tank through a bad seal and causing a fail, Dave from SAS was luckily on hand at Penrith and fixed it on the spot, resulting in an instant pass.
IM240 shouldn't be that hard to pass.
Garry
Postby Garry » Fri Sep 21, 2007 10:37 am
Not really related but.....
Daniel from Mania and other people bag out the tuning on the SP but it was tuned to meet the NEW car emmissions test which is much stricter than the used car test and it was done with the factory ECU which was never designed to run a turbo installation. I think the guys at Chiptorque and SAS did a pretty good job with what they had to work with. Pity Mazda Aus was to cheap to chip in with an upgraded ECU.
Now back to our scheduled topic.........
