car stutters at 1700-1800 revs under load
Bevan
Postby Bevan » Thu Aug 16, 2007 4:24 pm
Plugs and leads is the first thing to change.
No way should the revs be that low up a hill though. It's only a little 4 cylender so best to keep it about 3000 up a hill.
16bit
Vehicle: NB8A - Supercharged
Postby 16bit » Thu Aug 16, 2007 5:23 pm
what he said ^^ also make sure your gap is set correctly.
Bevan
Postby Bevan » Thu Aug 16, 2007 9:50 pm
Actually, just check to make sure that there isn't any moisture in the spark plug wells. Check this BEFORE removing your spark plugs...
Alex
Postby Alex » Fri Aug 17, 2007 12:10 am
:shock: I feel sory for your car, I never let mine get below 2000 when in gear even on the flats, at only 1700-1800rpm I wouldn't be using the throttle more than about 10-20%
the only time mine shudders is when I slow down really quickly from relatively high revs, ie stopping at traffic lights after a quick squirt on the throttle, but I assume this is just because the mixture is changing rapidly from WOT to idle
StanTheMan
Postby StanTheMan » Mon Aug 20, 2007 1:15 pm
as far as plug gap is concerened. yes 99% of the time they are set at the correct dist. However if someone accidently dropped the plugs on the ground just before installing them could cause the gap to decrease.
But certainly try the cheap alternatives first. Discount nothing.......even the new leads.
JBT
Postby JBT » Mon Aug 20, 2007 1:16 pm
SM wrote:....the only time mine shudders is when I slow down really quickly from relatively high revs, ie stopping at traffic lights after a quick squirt on the throttle, but I assume this is just because the mixture is changing rapidly from WOT to idle
Nup, there's something wrong there too.
Uncle Arthur
Dodgy Award Benefactor
Postby Uncle Arthur » Mon Aug 20, 2007 2:14 pm
Definitely sounds like leads, especially if above the 2k RPM band it behaves normally.........
Zimma
Postby Zimma » Mon Aug 20, 2007 8:31 pm
Maybe take a look at the coil pack... maybe on its way out. I know they can get fine fractures in them which can cause probs... just a thought.
ZIMMA
That's what the plates say!
