After i rev the car, as it comes back down to idle, i have this popping sound coming from throttle body /air intake. It is as if the car is backfiring, but the sound is much less. I can hear \"pop pop\" once or twice and the car idles normal without any noise.
I changed the ignition leads and changed the sparkies 5000 kays ago...
Did anyone experience this? any ideas?
Popping sound from Throttle body?
Do you have an NB8A??
I have an NB8A and i too get a popping/gurgling sound coming from my intake-podfilter
Ive noticed it for a while and it tends to do it when i move the steering wheel from side to side when the car is stationary and probably also when its moving but cant here coz of road noise.
If anybody else has had this it would be great to know whats causing it and why and if its causing damage to somthing
Cheers, Mark
Cheers, Mark
99 mx5, Brilliant Black with hardtop, cusco f/brace,intake and AVO turbo kit awaiting install.Tien SS coilover kit,BD Rollbar,16x7 Work Meister's!!
Yes it is nb8a, it started doing it 3 weeks ago when i put a pod filter... then i have taken the pod off, but pop sound is still there. I have also realised it happens when i drive the car, it does not happen too much when i rev it standing.
i just got some TB cleaner, and some iridium plugs, will remove the TB and give it a good clean/degrease tonite.
- Matty
Matty wrote:They all do that. You can just hear it now...
can anyone explain this and what causes it
Cheers,Mark
Mark, i have changed my tyres and rims to 17 inch and i have put on my pod filter. Car makes the popping noise since, and it makes it when i turn the steering wheel in idle....
I have also changed the spark plugs and they were black so my car is running rich. but i still dont know what makes this noise ...any help guys???
