Stock Engines and Turbo Kits
Matty
Postby Matty » Sun Jul 22, 2007 9:03 pm
ampz wrote:310000Kms and happily boosted :mrgreen:
Only 6 psi atm but with the right fuel management an easy 9 psi.
Am i happy?
You bet!!!
I hate you! I wish that car was boosted about 100000km ago... :cry: wa wa wah I'll go cry in my corner now..
ampz
Vehicle: NA6 - Turbo
Postby ampz » Tue Jul 24, 2007 7:37 am
Sorry Matty :(
If you move back to Oz I can help you get one together :)
The opportunity was too good to miss :mrgreen:
Huh?
Sean
Postby Sean » Sun Aug 26, 2007 2:52 am
Boags'MX5 wrote:A guy on the US forum ran 18PSI for 2 years on a bone stock engine. He drove it when the air was cold, had a good setup and a great tune. On a hotter day it pinged once and it was time to throw the engine in the bin.
You can root your engine on 6PSI if you run heaps of timing and no intercooler. Having seen UA's car I'd take Ryan's offer any day of the week if I had my time again. Looks the goods!
My car has 225000 on it now and doesn't blow a wiff of smoke, on 8 PSI.
I need a better fuel pump before I go higher than that.
Boags
If it's tuned well there is absolutely no issue running mid teens boost levels. Remeber than you do't actually run the MAXIMUM boost level every time you drive it, I could drive my (ex) turbo mx5 to and from work without mustering more then 4-5psi, even when the controller was set to 16... It's only when you mash the throttle that it sees big boost.
bigdog
King of the kennel
Postby bigdog » Mon Aug 27, 2007 5:14 pm
Sean wrote:I could drive my (ex) turbo mx5 to and from work without mustering more then 14-15psi, even when teh controller was set to 16... It was only when I mashed teh throttle at every straight stretch, traffic light, corner or car park that it sees big boost.
Corrected for accuracy... 8) :)
Cal
Postby Cal » Mon Aug 27, 2007 6:04 pm
lowmiata wrote:leave it with me for two weeks and some money and i'll do it!
Are you in Brisbane at the moment? It's come time to pull the blower off and replace with a snail. Motec, injectors, fuel pump ect are already done. Want to run 12-15psi on the stock 1600.
Cal.
Sean
Postby Sean » Mon Aug 27, 2007 7:30 pm
scerw yuo. :lol:
Boags
Postby Boags » Tue Aug 28, 2007 9:30 pm
scerw yuo. :lol:
:lol: :lol: :lol:
Return to “MX5 Motor Sport”
