Oil leaking, Pls Help or the turbo may have to go
bigdog
King of the kennel
Postby bigdog » Wed Aug 29, 2007 12:10 pm
If you have a build up of pressure in the crankcase from turbocharging the engine then your rings are not sealing correctly. Go to a good workshop and get a leakdown test done to confirm. The only other way to increase crankcase pressure is for PCV valve to block up. The pcv valve is found on the cylinder head on the inlet side on a NB8B. If you blow through it air should pass freely in one direction only, sometimes the ball valve sticks and blocks.
Juffa
Postby Juffa » Wed Aug 29, 2007 1:26 pm
Where is it leaking oil?
A standard NA6 has a rubber hose on the exhaust side of the valve cover than attaches to a chrome pipe that runs around to the front of the engine and connects to the inlet pipe. You should attach an oil catch can to where that hose attaches to the valve cover.
I have read on miataturbo net that for FI cars it is recommended that you replace the Positive Crankcase Ventlation (PCV) valve with one from a GTX (factory turbo), which I need to do myself.....not sure where to get one though...wonder if one from a SE or SP would do the job.
J
Garry
Postby Garry » Wed Aug 29, 2007 3:21 pm
AFAIK the SP uses the standard NB8B version. Go for the SE one if it fits.
Juffa
Postby Juffa » Thu Aug 30, 2007 1:10 pm
Flyin' Miata have one for USD$19.95 + postage.
www.flyinmiata.com
Do a search on PCV valve.
J
Uncle Arthur
Dodgy Award Benefactor
Postby Uncle Arthur » Thu Aug 30, 2007 5:46 pm
Juffa wrote:Flyin' Miata have one for USD$19.95 + postage.
www.flyinmiata.com
J
Buy it at a mazda/ford dealer. Less than $30. Looks no different to the standard one.
Juffa
Postby Juffa » Thu Aug 30, 2007 9:41 pm
www.flyinmiata.com
J
Actually the FM one (and possibly the SE one) have a larger spring to compensate for the additional pressure from the turbo.
J
Fatty
Postby Fatty » Thu Aug 30, 2007 9:58 pm
yep but they look the same, externally.
i still need to do this mod too.
ampz
Vehicle: NA6 - Turbo
Postby ampz » Thu Aug 30, 2007 10:54 pm
x3 :roll:
Huh?
Juffa
Postby Juffa » Fri Aug 31, 2007 3:18 pm
Oh, in case you are wondering if a stronger PCV valve is the way to go check this out.
http://www.miataturbo.net/showthread.php?t=9920
J
Users browsing this forum: No registered users and 19 guests
