Noisey tranny again
EGG80X
Noisey tranny again
Postby EGG80X » Mon Sep 03, 2007 8:41 pm
I noticed recently my gearbox is a bit noisey, a rapid rattling sound.... when its about 2000-2500rpm off throttle and about 1/4 throttle, The noise is not there when it is out of gear rolling or clutch is out of gear. Its not that loud but I do notice it when the roof is up
Please help!!!
EGG80X
Postby EGG80X » Tue Sep 04, 2007 10:54 pm
anyone?
JBT
Postby JBT » Wed Sep 05, 2007 7:46 am
Are you sure it's not a heat shield or some other thing attached/near the transmission?
Could be worn bearings or selectors - both are a gearbox out and disassemble job.
OMY005
Postby OMY005 » Wed Sep 05, 2007 7:52 am
http://www.aus-cartalk.com/viewtopic.ph ... 44846dd9f3
I had a listen to the car from the post above, it sounded similar to mine just a tiny bit louder.
I notice that when I have my hard-top on there is a very slight noise coming from the gearbox. Cant hear it at all with the soft-top up though.
Andrew. :)
Previously, White 95 NA 1.8 Hard Top,Stock standard
Now, 2016 Fiat 500x, 2014 Fiat 500, 2015 ND GT 2.0
JBT
Postby JBT » Wed Sep 05, 2007 7:55 am
Are the rubber shift lever boots OK? Could be letting normal noises through too.
metris
Vehicle: NA6 - Turbo
Postby metris » Wed Sep 05, 2007 9:58 am
this sounds similar to my car... there is this quiet but harsh rattle coming from the gearbox or diff... but seems to be mostly on deceleration.
i hope its just my shift lever boot.
how do you check that?
JBT
Postby JBT » Wed Sep 05, 2007 10:07 am
Remove the centre console. Then remove the rubber boot (called an insulator) - it could be split and broken - around the gear lever and you'll see a smaller one where the lever goes into the gearbox.
metris
Postby metris » Thu Sep 06, 2007 2:07 pm
cheers thanks!
will check it out...
EGG80X
Postby EGG80X » Wed Nov 07, 2007 1:06 pm
hmmm its getting a bit annoying now, using different gear box oil had quiten it down a bit
check both the rubber boots... no rips
ummm seems like now the rattles happens even with the clutch depress/disengage. It rattles only at 1900-2100rpm on and off throttle
metris
Postby metris » Wed Nov 07, 2007 1:10 pm
It could be the compression plate touching the flywheel... or something along those lines...
i am no mechanic so possibly suggest this idea to one, and see what they have to say.
I was told that this is why my car was making that noise.
Hope this helps...
NA6 turbo cute scary fun machine!! :D
Postby manga_blue » Thu Nov 08, 2007 1:50 pm
Engine mounts stuffed? Something like a bolt or rock jammed somewhere between the engine or gearbox and the bodywork or subframe?
